Question about iRiver H10 MP3 Player
IRiver H10 I have plugged my H10 into a DC 12v/ 500mA car cigarette lighter charger and i have blown the fuse in the charger. My H10 will now not turn on. Have i blown a fuse in the H10. If so is it possible for me to take this apart and fix myself.
  • Anonymous Jun 23, 2008
    I did the exact same thing. Wished I had read the back where it said it only accepted 5 volts. Can't find small enough hex bit driver to get the case open.
    Problem Solver:
  • 8 Answers
Require more history 1/condition of H10 battery B4 this problem (blown Charger Fuse) occurred 2/perhaps battery condition severly depleted creating high current draw upon initial charge attempt 3/not certain if an circuit protection fuse exists in H10 4/Chk charger wiring for shorts bare contacts etc.
Posted on Apr 22, 2007
SOURCE:
Two specific fuses keep blowing immediately - even before the instrumentation they govern can be utilized.
take it back to the dealership where you bought it. You have a dead short to earth in those circuits.
May 29, 2016 | Cars & Trucks
Cannot find the charger for my vectorlite 1.5
Hi sast.
I found this on amazon: HQRP AC Adapter Charger for Black Decker VEC119SH TYPE 1 VEC120 TYPE 1... It says that fits, but anyway contact the seller and ask.
Hope this was helpful.
enjoy
Feb 28, 2011 | Vector 1 Million Rechargeable Spotlight
Suddenly I can not charge my iPhone 3gs (iOS 4.2.1) with my 12V charger in the car. Any idea what is wrong ?
When pluged into the car liter outlet does the moniter light come on? 1 check the fuse by unsrewing the pin tip of the plug, look to see if the fuse is blown, you may need a OHM merter if you can't see if the wire is still in one piece. 2 check the cigar lighter in the vehical with another plug or lighter to see if it works if not then find whitch fuse is blown in the fuse box of the vehicle, and replace either or both.
Feb 10, 2011 | Apple Car Charger for iPhone 3G (12V~24V...
Nuvi will not charge when plugged into car charger but will charge when plugged into house charger
  1. Check that the cigarette lighter socket is working. If not it may be a fuse blown in the fuse-board.
  2. In the charger plug, that goes into the cigarette lighter there is a fuse which may be blown. At the tip of the plug you'll see a ring. On most chargers it's silver but some are black. Unscrew the ring and the plug will come apart. Take care not to lose the small metal tip when you open it. Replace the fuse. If there's power going to the charger and this fuse is replaced your problem should be solved.
Dec 17, 2010 | Garmin Nuvi 770 Car GPS Receiver
Any kind of charger that i attempt to plug into my cigarett lighter don't charge the devices, does this mean that the fuse has blown and needs replacing? thanks in advance!
The charger should have a light which shows that it has power. Check power at the socket by operating the cigarette lighter. If the lighter heats up you have power at the lighter. If not, locate the fuse box and check the lighter fuse. If the fuse is intact and you have power at the socket the charger is faulty.
Bear in mind chargers also have a fuse in the connector nose. Most unscrew at the nose and the fuse can be removed from the charger.
Sep 04, 2010 | Ford Focus Cars & Trucks
Nokia 3310 charger.. won't charge help me..
if its the car charger check the cigarette lighter fuse and also the charger fuse
Sep 25, 2009 | Nokia Car Charger: 3310 3360 3390 3395...
My garmin charges with my computer but stopped charging in the car
The most obvious answer is a possible blown fuse in the cigarette lighter socket or the in the tip of the charger plug. Most charger plug fuses are accessed by unscrewing the metal tip. Check both for good fuses.
If this doesn't solve the problem, make sure the points of contact between the charger, cradle and GPS are all free of dirt and grime. Don't forget to vacuum the cigarette lighter socket - especially if it is used as a lighter, too.
Sep 16, 2009 | Garmin nuvi 200W GPS Receiver
Fuse blown on cigarette lighter Saturn 2001
It sounds like you have a bad charging cable for the GPS or the cable is overloading the cigarette lighter.
The cigarette lighter is designed for less power then a 12v power outlet.
Therefore it is easy to blow the fuse for the cigarette light if you install something that draws too much power.
Jul 07, 2009 | 2001 Saturn S-Series
Cigarette lighter is not working at all....
sounds like you have a blown fuse to your cigarette lighter. look in the fuse box for a blown fuse.
Apr 29, 2009 | 2001 Hyundai Accent
Cigarette lighter sockets no power
Cell phone chargers commonly blow the fuses at the power points. It seems that our charger adaptors do not match the socket properly, and the positive part of the charger hits the negative of the socket, resulting in a blown fuse. If you have a charger, and it works, leave it in the socket. Don't take it with you. Repeated insertions of the adaptor to the socket magnifies this issue.
Jul 16, 2008 | 2002 Toyota Camry
iRiver H10 MP3 Player Logo
237 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
