Question about ASUS GeForce FX 5600 (256 MB) AGP Graphic Card
Problem with Nvidia GeForce XF 5600 AGP graphics card...
When i first got the card with a different computer it worked fine, but then the old computer (this was about 2 years ago. almost 3) died on me so i gave the graphics card to a friend to put in his till i could replaced the m/bored and processor. i just got a K8V-X SE mainboard and a semperon 3400 processor and it works fine, plugged in the graphics card and during a few of the games it will work beautifully. but with other games such as: americas army, freelancer and Rome Total War. after a short period of time, say...10 mins? at the most. the graphics will become pixilated? is the best way i can really describe it. after this has happened the card gives the same pixilated graphics on all games and even in the softwear from nvidia where you can chose the type of 3d image you want to go for. performance/quality etc. untill the computer is rebooted then it is fine untill you use one of the games again. it turns out that the person using the card while i wasnt for the past few years had also had this problem latley but not always? is it that the card is over heating or some such? anything i can do or should i just get a new gfx card?
I also had this problem. I solved it by installing OLD nVidia drivers (56.72). Hope that helps!
Posted on Nov 24, 2006
    President:
  • 2,961 Answers
It does sound like an overheating problem, although i have also found that this card doesn't work particularly well on all AMD motherboards, although it's an asus card and asus mobo you are using, it is the nvidia chip. You may find an ATI chip card works better on your board. Also check the voltage on your AGP slot as newer cards work on less voltage than the older ones.
Posted on Nov 13, 2006
SOURCE:
I need Nvidia GeForce 6600 / 256MB DDR / AGP 8x / DVI / TV-OUT / Video Card Graphic Card how can i buy this item??
PC shops, online PC shops or even ebay.
Here's the URL to the Nvidia website, Click on the "BUY" tab at the top.
http://www.nvidia.co.uk/page/geforce_6600.html
Dec 02, 2010 | Nvidia GeForce 6600 Graphic Card
I have a GeFORCE FX 5200 PCI card, and onboard graphics. I had to restore my system, and cannot find the user manual. If it was available online, I'd follow the steps myself, but I'll settle for a quick...
Hi.
You do not necessarily need to disable the built in graphic adapter, the computer can manage two different adapters.
The nVidia should show picture with standard VGA definition (800x600 only) if simply connected to the AGP or PCI slot even if drivers are not installed, and even if built in GPU is not disabled.
If there is no picture, check installation in slot, check that card is not disabled in BIOS, check video cable is well connected, and if nothing works, test the video adapter on different PC, the card may be faulty.
Here the manuals:
Quick Guide to NVIDIA GeForce Desktop Graphics Processors
GeForce FX 5200/5500/5600/5700/5900 Series
GeForce FX 5200/FX 5600/FX 5900 Series
nVidia GeForce FX5200 Gigabyte GV-N52128DS manual - GeForce FX5200 ...
Sep 30, 2010 | Nvidia GeForce FX 5200 Video Card Graphic
My nvidia geforce 6600 256mb video card not being detected...
I feel you got a failing video card my friend as if the slot failed you would not have got that far!.
Try another video card, you can get them cheap from Fry's.com hold on to your receipt just in case you have a failed motherboard (witch i can doubt that)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 07, 2010 | Nvidia GeForce 6600 Graphic Card
Will a NVIDIA GeForce FX 5500 video card work on a P4B533-E motherboard?
HI Lau_kua08,
First off, your motherboard is a AGP 4x slot, and the Card is a AGP 8X card. However, NVIDIA based graphic cards which support AGP 8x mode (Accelerated Graphics Port) follow the AGP 3.0 specification. The AGP 3.0 specification retains backwards compatibility with older AGP 4x technology. All NVIDIA Geforce and Quadro GPU's which support AGP 8x mode are downwards compatible with AGP 4x motherboards. When a graphics card which operates at AGP 8x mode is installed on a motherboard which only supports up to AGP 4x mode, the card will automatically switch to AGP 4x operation.
So, yes it will work.
Good Luck,
Mark
Oct 27, 2009 | ASUS P4B533 Motherboard
Nvida geforce fx5500 256 agp compatible with intel d865gbf ?
Yes, they should be compatible. The Intel d865gbf has an AGP port that supports AGP 4x/8x, and so does the FX5500. You should be fine.
Nov 05, 2008 | Nvidia GeForce FX 5500 Video Card Graphic...
Is my Motherboard compatible?
Try to find out what the AGP voltage is on the motherboard.
Some graphics cards use 1.5 volts and some use 3.
If it's a 1.5 volt AGP slot and you plug a 3 volt graphics card in, it either wont work or you could permanantly damage both card and motherboard.
Mar 07, 2008 | Computers & Internet
ASUS GeForce FX 5600 (256 MB) AGP Graphic Card Logo
135 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
