Back to:
Tags:
Emerson Multimode LC/LC Duplex Fiber Riser Cable - 22.96 ft
Emerson problem
By Melissa - usenet poster
I have a 27" emerson ts2762d.The problem is difficult to describe but I,ll
try.There is a ghosting or fading around objects on the screen.When I
put a crosshatch pattern up it appears that the convergence is way off.
Unfortunatly I can,t get a sams for this model so I dont know how to access
code for adjustments.
  Any help would be appreciated.
-----------== Posted via Deja News, The Discussion Network ==----------
http://www.dejanews.com/       Search, Read, Discuss, or Start Your Own
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 04, 2005
Not Rated (0)
Peter1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
What adjustment codes do you want?
If it is less than a 3 year old Emerson you will have very basic aft, gray
scale, and a couple of other adjustments from the service menu.
If you convergence is actually off, you will need to properly set up all the
yoke adjustments.
David
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on emerson problem:
I don't want to Accept this solution
Can you Help with these Network Cables problems?
Network Cables
Hi, I recently moved to a new house but there were no...
Network Cables
When you plug the phoneline in the digi box it cuts the...
Network Cables
need a PCMCIA to RJ? cable for ATT internet service....
Network Cables
I purchased a Vextra Digital Photo Frame at a yard sale,...
Network Cables
I am trying to connect my satellite receiver to my pc; but...
Loading problems.
Repair Service
Find Network Cable Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
