Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Thin twin stacked washer/dryer...dryer won't stay on
Dryer will only run for about 1 minute, then turns off. I tried changing the timer, to no avail. Gonna change the high limit next. Any suggestions?
  • 1 more comment
  • andrewl4 Feb 21, 2009
    The dryer starts and only stays on for about 3 min. I did a thorough cleaning on it hoping that would fix it.......didn't work. It almost sounds like its having to work too hard. I was thinking maybe the belt, but if the motor isn't turning, I don't think the belt is the problem. Is it a sensor or what?
  • xxodiaq Feb 25, 2009
    fixed the same problem...bad motor
  • andrewl4 May 11, 2010
    I am checking the sensors just to make sure that isn't the cause, but I have a feeling its probably going to be the motor and ofcourse, its the more expensive fix
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Posted on Apr 06, 2012
  • 640 Answers
I take you mean the hold dryer shuts down,,,not just heat,,,bad motor..
Posted on Dec 25, 2008
Dryer is taking too long to dry, can the element be worn out? whirlpool, thin twin heavy duty, large capacity
If it heats the element is good. Most likely cause is bad ventilation. check the vent on the outside of the house while dryer is running to make sure you are getting plenty of air flow. If you want to check to make sure its working properly general rule is 6 towels should dry in 60 minutes.
Sep 20, 2010 | Whirlpool LTE6234D Top Load Stacked...
Dryer will not turn on. I hear a faint electrical sound when I push the start button but the dryer will not start. It worked fine through the last cycle. This is a stacked washer/dryer model & the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Aug 21, 2010 | Whirlpool LER4634J Electric Dryer
It's heavy duty thin twin model. The cycle stops at spin and water stays in the mashine.
When it gets to the SPIN cycle,wait 45 seconds. If it does not spin,open then close the lid.
If it spins then,replace the timer.
If it does not spin,replace the lid switch.
Jul 27, 2010 | Whirlpool LTE6234D Top Load Stacked...
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
342 people viewed this question
Dan Webster
Dan Webster
Sal De
