Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Height adjustment on power mate doesn't work
Sears Kenmore vacuum
Power mate attachment
Height adjustment doesn't work. Stays in one position.
reddevil6
  • 1673 Answers
SOURCE: Sebo X1 vacuum not working
The X1 has a servo motor with gear box, this is what adjusts for height. Either something has jammed it, or
it has gone bad. You would probably be looking at a $80 to $100 repair, that is if the servo is bad. There also is a computer controller circuit board which could be the problem.
Posted on Mar 13, 2008
RockyNR1
  • 324 Answers
SOURCE: Kirby vacuum height adjuster is stuck in high
Remove the nozzle and remove the front wheel shaft. Take these 2 screws out.
When doing so - watch for the spring that is under the top pedal, do not let it fly out of window. If you will find that shaft is bent buy and install a new shaft (you can find all parts HERE). You may try to straighten it but usually it doe not last long - wheel ***** falls off and you have to buy new shaft anyway. If shaft seems to be ok - clean old grease and dirt, lubricate well the pedal teeth and assemble everything back. This should solve the problem. Occasionally spring may be broken but this happens very rarely.
Good Luck,
Rocky
Posted on Apr 10, 2009
renevacdoc
  • 84 Answers
SOURCE: bissell powertrak is stuck in the high position,
Hello. The height of the wheels Will stay in the highest position until you release the handle release lever. At that time the adjustment will happen. I hope this helps. let me know.
Posted on Aug 07, 2009
SOURCE: vacuum height won't go on low carpet setting.
Make sure you're not trying to adjust w/ handle in upright locked position because thewre is a cam which raises the vacuum head a little bit when handle is locked in upright position. If this is not the problem, turn vacuum upside down with handle in unlocked position and power cord not plugged in(for safety reasons obviously), unscrew and remove 3 screws that hold belt/beater brush assembly cover in place(2 are in corner near ends of beater brush and 1 is towards motor housing) tilt end of cover with 1 screw up and remove cover(there are 2 tabs at beater brush end of cover). Right above this is the height adjustment assembly with 2 rollers, raise up the assembly gently and using your finger or a bristle bottle brush,etc. make sure there is no debris caught between the height assembly and the hose(you will understand when you see it), if there is no debris you can now see the pattern on the bottom of the height adjustment knob and the lobe that rides on it, just check to make sure nothing is broken and/or missing, hope this helps!!
Posted on Dec 29, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Posted on Dec 30, 2009
How to change height adjustment on kenmore canister power-mate?
My powermate has a little pedal on the bag of the beaterbar housing that you press all the way down with your foot and then release. Each time you press down it changes the height from 'xlo' to 'lo' to 'med' to 'high' and then it starts over again.
See the attached picture
Mar 23, 2016 | Kenmore Vacuums
Can I fix the high, medium, low level switch on vacuum piece?
The height adjustment lever on Kenmore Power Nozzles is one of the machine's weak points. It's not well made as far as being protected from dirt and dust and moisture. It's always easier to move these things when the vac is on it's side or at least with the front end in the air. That takes the pressure off the adjuster. The mechanism may need nothing more than to taken apart in the presence of a good air compressor which can be used to blow out any of the aforementioned debris.
Nov 11, 2013 | Kenmore Vacuums
Bissell 3576 height adjustor broken
Hi Chris! Lock the vacuum in the upright position, set the height adjustment to the desired setting, then recline the handle for the change to be made.
If you continue having difficulty, you may want to have one of our Authorized Service Centers inspect your vacuum.
Here's a quick link to help you locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
May 19, 2013 | Bissell 3576 CleanView II Bagless Upright...
I have a dirt devil vision wide glide, 086700, made may 2006. I found 2 places with reasonable prices and the same excellent explosion diagrams. www.ereplacementparts.com and www.vacpartswarehouse.com hope...
Do you know how to get the height adjustment knob to release the wheel height? Its stuck on high carpet? The knob moves but doesn't change the position?? Identical Vacuum.
Feb 27, 2011 | Dirt Devil M086700 Vision Bagless Upright...
Owners manual for kenmore power-mate # 116
Greetings from GoVacuum,
I wasn't able to find the manual for the Kenmore model, however I did find the instruction manual for the corresponding Panasonic canister vacuum cleaner. Your particular Kenmore model is actually made by Panasonic for Sears, and then Sears puts the Kenmore name on the vacuum cleaner. They are identical internally, and have the same parts and components, besides the filter that is behind the bag. Sears makes Panasonic put a specially designed filter in the Kenmore's so that the customer has to go back and purchase that filter from Sears.
To download the instruction manual, please visit the link below;
Owners Manual For Sears Kenmore Power-Mate Model 116.3489890C
You can also find a parts schematic of the power head below if you need to purchase parts;
Parts Schematic For Sears Kenmore Power-Mate Model 116.6489890C
I hope that this information helps you. Please let us know if we can provide you any further service, or if you have any further questions we can answer. You may email me at chris (dot) jones (at) govacuum.com.
If this helped you, please click the Helpful button below.
Chris Jones
GoVacuum.com
Mar 18, 2010 | Kenmore Vacuums
Vacuum height won't go on low carpet setting. Dial will go on medium and high, but not low.
Dec 29, 2009 | Hoover Vacuums
Have an old power-mate 116. The height adjustment
Push in on each side of the light cover on top and it will pop off. Then you can remove the (2) access screws. With the screws out the top cover will separate from the base.
Nov 02, 2009 | Vacuums
Bissell powertrak is stuck in the high position, knob moves/changes but the height stays on high
Aug 06, 2009 | Vacuums
Height adjustment on power head
Generally, there are screws that hold the beater bar onto the vac head.  Loosen them, remove the glop that got in there and you should be okay.  If you remove the screws, note the location of all parts...Digital cameras are great things. If you forced the adjustment, you may have broken or bent something.
Nov 29, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Replacing Power Cord to Power Nozzle
The height adjust mech. has 2 tabs, that you have to unlock, It also is easier when you tip the power head so as not to puit pressure on the Ht. Adj. wheels. Use a flat blade screwdriver and if you look down bertween the ht. adj. mech. and the elboe where the wire is, you should be able to see the 2 tabs, just pry it away form the elbow and it will come off. When you put it back on, make sure all wires are routed where they were and tip powerhead, it will snap into place.
Feb 14, 2008 | Kenmore 22812 Bagged Canister Vacuum
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
158 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
