Question about Roper RS25AEXLQ Side by Side Refrigerator
Spring on ice dispenser door came off but I can't get in to fix.
RS25AGXNQ00 side by side. I need to get the front cover off the front panel of the ice dispenser but don't want to pry and possibly break it. Is there something I should know about prying the cover off without breaking anything. I want to put the spring back on the ice dispenser door that is just dangling.
  • Anonymous Mar 30, 2009
    I have the same problem. The spring on ice dispenser door came off ----
    I have a Model RS25AGXNQo1 and the spring in the ice dispenser came out...
  • 4,070 Answers
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Posted on Aug 14, 2009
Fixing in door ice dispenser
What is the model number of the unit?
Nov 23, 2012 | Kenmore Side by Side Refrigerator
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
How do you remove the face plate off of the ice/water controls on the outside of the freezer door? The spring came off the flapper door that covers up the ice delivery hole, nothing has broke, but I need...
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I need to replace the torsion spring on the ice dispenser door. I have a new spring but can't figure out how to take the front cover housing off in order to get to the spring. Thanks, Jeff
there should be two small holes on either side of the face plate,
push a small nail in those the face plate will pull off
once you have the face plate of, it should be fairly obvious how to remove the padles and springs
hope this helps
Oct 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The spring came off our ice dispenser
there are 2 notches on the bottom of the dispenser front insert a flat blade screw driver and gently pry it off. chances are you are going to need a dispenser door repair kit pt#8201756 IN ORDER TO COMPLETE THIS REpair in most cases the plastic hinge for the door breaks off causing the door to fall off. good luck peyton
Jan 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Front Cover to Ice/water dispenser
YOU WILL FIND TWO PHILLIPS SCREWS UNDER THE FRONT PANEL AT THE BOTTOM YOU NEED TO BEND DOWN TO SEE THEM.IT THEY ARE NOT THERE THEN YOU WILL NEED TO REMOVE THE ENTIRE DOOR LINER ITS BEST YOU GET THE HELP OF A TECH.LET ME NO IF YOU NEED FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice dispenser spring in door
There should be two slots in the bottom of the panel. Use a screwfriver to pop this out. You will have to unscrew the electrical panel to expose the dispenser area. Be wure to unplug the unit first and be careful not to break any wires.
Aug 06, 2008 | KitchenAid KSCS25IN Side by Side...
Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Whirlpool refrigerator ice dispenser
The front cover is snapped on. There should be two slots in the bottom of the cover. Put a wide screw driver in the slots one at a time and pry out. It snaps off very hard.
Apr 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Roper RS25AEXLQ Side by Side Refrigerator Logo
725 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
