Question about SansuiM1315 TV
Power on and off with ''ASM after 3 sec'' message
My sv2918 tv goes on then off with a error message"ASM after 3 sec" . please could some one shed some light on this problem. must also say the tv is 7 years old. tx
  • ismail884 Jan 11, 2009
    At swicht on I have a red display "ASM AFTER 3 SEC" and the set goes to search mode.
5 Suggested Answers
SOURCE: sansui tv sv2918
Sweetch on thr tv just one vertical line comming in center of ty screen
Posted on Jun 20, 2008
replace vert IC301, C432, ( D431 & R431 should also be blown)
Posted on Nov 26, 2008
gopakumarg43
  • 74887 Answers
SOURCE: sansui tv asm after 3 sec error
Replace its system memory IC.
Posted on Dec 18, 2012
gopakumarg43
  • 74887 Answers
SOURCE: asm after 3 sec
Automatic Search Memory [ASM] fault must be due to a defective system memory IC. Replace it.
Sansui sv2918
Main system control memory IC fault. Replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 29, 2014 | Televison & Video
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
Www rockauto com
hi Robert
do this procedure and your Nissan will be OK
switch ignition ON till airbag light goes OFF briefly ( approx. 7 sec) immediately after light goes out turn ignition OFF for 3 sec,
repeat this 3 times, after you switch ignition OFF 3rd time for 3 sec
switch ignition ON for 1 sec then OFF, again switch ignition on and start the car, the AIR BAG light will goes OFF.
let me know how it goes
good luck
Feb 04, 2014 | Nissan Armada Cars & Trucks
Asm after 3 sec
Dec 18, 2012 | Sansui Televison & Video
Sansui tv asm after 3 sec error
ASM after 3 sec
i think you should check sleep mode on your TV remote.
set the time on this mode.
hope it will help to rectify the problem
Dec 28, 2011 | Televison & Video
When I switch tv on at button on tv I van hear the tv goes on. No Picture. If I press buttonds on the remote I can see the red light come on that indicate the remote is sending signal. Here comes the best...
Replace , front panel switches , one or more switches goes high resistance
when suppose to be open circuit , my sv2918 74cm was doing weird things
with these switches going bad
May 10, 2011 | Sansui D 27" TV275 TV
My television is showing a message on the bottom of the screen ASM in 3 sec and then shuts of and on by itself what is causing this and how can I reset this problem
if your tv is a panasonic, you need replace stk ICs. if you need help in the future, please provide model number tv,'
Thank you
Aug 05, 2009 | Televison & Video
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Picture appears for 3 sec then shows no signal
HELLO MAKE SURE ALL THE CONNECTOR CABLES ARE TIGHT ON THE MAIN BOARD IF THEY ARE OK CHECK THE INVERTER BOARD FOR DRY JOINTS GOOD LUCK
SHAUN
Apr 27, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
SansuiM1315 TV Logo
623 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
