Question about Samsung SF-5100 Plain Paper Laser Fax
CAN NOT FAX
EVERY TIME I TRY TO SEND A FAX THE FAX MACHINE DOES NOT FEED THE PAPER AND DOES NOT GO THROUGH. WE GET AN ERROR MESSAGE SAYING RECEIVING ERROR AND WE DO GET A DIAL TONE.
HELP US, WE HAVE NO PROBLEM RECEIVING FAXES FROM OTHERS, BUT CANNOT FAX OUR DOCUMENTS.
    Problem Solver:
  • 16 Answers
Hade the same problem it is the main board. We do not get it any more in Namibia. hade sume scrap. If you make a copy do it work?
Posted on Mar 11, 2010
Fax will send but not receive faxes. Says printer
Mite need to clearthe memory of the fax machine
Mar 21, 2010 | Sharp Office Equipment & Supplies
Fax reception fails
Hello Dear,
The error message 242 appears in HP Photomart C7180, when the remote machine (the fax machine at Fax Sender side), is having problem, and it is trying to receive fax instead of sending. So actually both these machines try to receive the fax at the same time.
On many fax machines it is possible to accediently initiate the fax reception when:
1. The paper is not loaded in the machine
2. Or The paper is not correctly loaded.
You may contact the fax sender to check the above things. There is absolutely no problem with machine at your end.
Thanks
Mar 10, 2010 | HP Photosmart C7180 All-In-One InkJet...
Cant Send or Receiver. Message says Check Printer
Any numerical code displayed with 'check printer'?
Dec 16, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Samsung SF-5100 Plain Paper Laser Fax Logo
143 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
