Question about HP Compaq nx5000 Notebook
HP Compac NX5000 wont load XP Home on new hard drive
Hello, I am attempting to load XP Home on this laptop. The computer sees XP, goes through the format stage OK but when it gets to the section of loading all the files, I get a message "cannot load file.... XP may not work properly if you continue - press f3 to exit". Is there something I am missing? When I replaced the hard drive, I noticed a jumper on the pins on the old one that came out. I did not replace the jumper on the new drive.
Thanks for any help.
Scott
  • archmuk Mar 06, 2009
    I also hv the same problem. First i thought that the HDD has crashed. I replaced the HDD but the problem is the same. The OS CD and the DVD-ROM drive appear to be ok.
    Sergeant:
    Champion:
  • 318 Answers
This situation leads me to believe that the CD or DVD drive is faulty,,or the install disc you are using is scratched or dirty.
Try cleaning the disc and begin again.
Another option is to take the hard drive out and using a 2.5 to 3.5 inch HD adapter ,,plug into a desktop PC as a slave.
And copy your WinXp cd onto a partition on your laptop HD.
Then using a Win98Se floppy boot disc you can access the winXP and install from there.
Posted on Jan 29, 2009
How to light on the screen again?
If this is an XP machine, it is no longer supported. I recommend backing up your personal data asap. If you have important files on it, you could purchase a USB Hard Drive Adaptor, pull out the hard drive, and copy any important files to another machine. Then you could try doing a System Restore if you have the disc.
Jul 14, 2014 | HP Compaq nx5000 Notebook
Problem with HP pavillion ze4900 harddrive. bios says no IDE device when trying to find hard drive.
You can try to boot from CD/DVD drive with XP cd to see if the install program can find the hard drive. Try to use default setting in the BIOS.
Sounds to me like your hard drive crashed. I had one that did this and same thing. You can either replace the hard drive, use an external hard drive/flash drive (load the os and download laptop drivers) or use a cd based OS like Knoppix.
If you need help with the XP CD let me know.
I hope this helps!!!
Jan 22, 2013 | Computers & Internet
When booting up my computer it goes to the error page prior to loading windows and asks what mode...regardless of choice it goes to windows logo screen and sits there and wont load...
1. check to see if your pc is compatible with the software. You didn't specify if you are reloading or installing for the first time.
2.You didn't give hard drive capacity or any information about the Pc you are loading Windows on.
You may not have enough capacity on the hard drive to load the full XP
Wndows xp requires about 2 GB of hard drive space then at least 10 GB of space for swap files and operation files.
Jun 13, 2010 | Compaq MS Windows XP Home Edition for PC
I have an hp pavilion a1410y. the computers harddrive doesnot do anything but make noise so i installed two other harddrives out of other computers one of the harddrives has xp professional and the other...
The reason it wont boot from your other hard drive is because windows is expecting some different hardware on *********** bored, gets stumped and falls down.
On your computer there should be a license sticker. This will be rectangular with a green pattern on it. It will have your product key for what ever version of XP you are licensed for. You can place the drive which matches your version in your computer. Then, in order to get that install running on the new board, you will need an OEM copy of the appropriate windows disk. you may have received one with your HP, or talk to your geek friends who may have one.
to repair the load, boot off the cd. You will come to a window where you can press R (dont press R) for recovery console, F3 to quit, and Enter to continue. Then you will see a license. Press F8 to accept it. Then you will see a thingy that says "serching for previous versions of microsoft windows". Then it will show you the partions on the drive. select the OS one, usually marked "C". And there should be an option to press R for repair. Now you can press R. It will ask you for a product key. That is the one on the license on the side of the computer, also known as a COA (Certificate of Authenticicty). It will ask you for some other things too, like user names etc. Then you get to go hunt for drivers on the HP website. Lots of fun.
Sep 01, 2009 | HP Computers & Internet
Laptop not booting up after XP install
Can you press f10 to get to the HP recovery screens?
May 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
New hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Pavilion ze2000 Notebook
Computer never starts
You just Replaced 2 things that have nothing to do with your Issue...
You Need to check your RAM and Hard Drive....Reseat Your Ram and test it
Also Make Sure Your Hard Drive is correctly in its slot..
That Make / Model is known for having a Faulty Nvidia CHip... Which causes that rebooting... Not Sure If THats Whats Happening with yours.. But Look Into It... They Are Repairing These Boards due to Recalled Chips...
Try Removing Your WiFi Card and Your Hard Drive....Remove Your Battery as well.... Plug In AC Adapter and try to power on the laptop.....
Nov 17, 2008 | HP Pavilion ze4365us Notebook
Toshiba tecra 9000 wont start
Blue screens are generally operating system failure. You will need to reinstall your XP home. Format the drive NTFS, instead of FAT32. If you have any problems during or after the reload, then the hard drive is the failure and will need replaced.
Jul 01, 2008 | Toshiba Tecra S1 Notebook
Drive letter assignments
Goto Control Panel>Administrative Tools>Computer Management>Disk Management.
Right click each drive to assign new drive path.Save & reboot.
Check My computer for changes
Feb 02, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
HP Compaq nx5000 Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
