GE Profile Spectra JGBP90 Gas Kitchen Range
Problem for GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile XL44 Spectra gas oven
By Carol M on Nov 13, 2006
Yesterday I put the oven through the self-clean cycle and it seemed to run fine. I pressed self-clean, the display showed 4.00 hours, I hit start and off it went. The display then showed "oven clean/locked door", and the timer ran down from 4.00 hours. When the cycle ended 4 hours later, I had a clean oven, however, the locked door display would not go off. My husband managed to get the door open, but now the oven will not work - bake or broil. When I try to select the bake or broil function, it will not allow me to set the temperature. The range top burners all work. The door opens and closes and appears to latch properly.
I set it to run the self-clean cycle again, and the display showed all of the appropriate messages, however the oven door did not lock. I stopped the cycle after about 10 minutes.
Probably important: about 1 year ago I had food placed too close to the broiler and the oven caught fire. It was quickly extinguished, but ever since I turn on the oven to bake or broil, the top of the range gets hot - hotter than it used to. It is almost too warm to the touch, as if I burned through the insuluation. I have not put the oven through the self-clean cycle since the oven fire - until yesterday. I have been baking and broiling without incident until yesterday.
Same Problem
Feb 14, 2008
-   I have the same problem, but I have no numbers to do the reset...help-   whitneymco
Jan 18, 2008
-   My Profile XL44 started taking forever to come up to baking temp a couple years ago. I cleaned and all worked again. Now same thing and I had been doing long slow cooks @ 200 degrees. Suddenly the baking element does not work. I self clean and it works for one week then quits again. Now during clean the cycle ends early because the akng element does not come on --- please help! It worked fine last week!-   Hmmmmmmmm
Jan 10, 2008
-   I have the same problem - my GE Profile XL44 Spectra gas oven quit working. I had left some food warming - below 200 degrees - a beeper went off as though the cooking timer or kitchen timer had been set. No timer was set. My daughter turned off the oven. It hasn't worked since.-   Guest
Best Solution
posted on Nov 13, 2006
Very Helpful)
catriver
Rank: Guru  GE Expert
Rating: 94%, 3177 votes
Carol, let me see if I can help you with this. First try killing the power to the oven for 30 seconds and see if the locking mech resets. If nothing changes try this: kill the power for at least ten seconds, power back up,simultaneously press the cooking time, delay start and the number 8 pad. Test should appear in the display. Press and hold the self clean key, this will test the lock motor and cam assy. The display should show 2 on the left (for locked) and change to 3 on the left for unlocked. Travel time of the cam will display a 0 between locked and unlocked. You must hold the self clean key for these changes. This latch mechanism is thermally controlled and sends a message to the main board to lock and unlock during self cleaning. We are just bypassing this with this test. Your temperature sensor may have gone bad during the self cleaning cycle. This is the probe located in the oven cavity. If you know anyone that is handy with a meter, it should ohm out at 1092 ohms at room temp. If this checks out, someone will have to open the top and check the lock motor and cam. Catriver..post back.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 26, 2007
Helpful)
StoveLock
Rank: Apprentice
Rating: 95%, 5 votes
I have the same problem, but no numbers on the keypad to allow me to press #8.
Was this helpful?
Yes
No
Solution #3
posted on Nov 22, 2009
Very Helpful)
duffer2001
Rank: Apprentice
Rating: 100%, 1 votes
Hi I had a very similar issue that I finally resolved yesterday. I ran the self-clean cycle but wanted to go to bed so hit cancel with about 1 hour to go. The oven showed "door locked" but I simply thought this was because the oven still had to cool.
In the morning though the oven still showed "door locked" and I was unable to open door. I spent hours trying to find a solution on the internet plus on the phone with GE. Then yesterday I finally fixed the problem.
Hopefully this will help others with the same issue.
If you have the same problem where the door is continually locked after a self clean cycle unplug your oven for at least 24hrs. Next gently lift the door by the handle and wiggle it upwards. If you do this correctly you can get the oven door open. However do not force it! Just gently wiggle the door upwards and forwards and it should open without any issue..
Next plug the cooker back in. If like me the cooker still shows "door locked" you need to do 1 more step. On the front left of the cooker just behind the door there is a black button. Push this button and hold it in, then press the cancel button and hold both for about 30 secs.
If you have doen everything correctly the door should unlock and you can use the oven for cooking again!
Was this helpful?
Yes
No
Solution #4
posted on Feb 04, 2009
Not Rated)
v_mertz
Rank: Apprentice
Rating: 0%, 0 votes
GE PROFILE GAS RANGR STARTED THE SELF CLEAN BUT FORGOT TO TAKE OUT RACKS SO I STOPPED THE SELF CLEAN BUT THE DOOR IS LOCKED AND THE LIGHT KEEPS FLASHING LOCKED
Was this helpful?
Yes
No
Popular Solutions for GE Profile Spectra JGBP90 Gas
Questions and Unsolved Problems for GE Profile Spectra JGBP90 Gas
Do you recommend GE Profile Spectra JGBP90 Gas Kitchen Range?
Answer
Answer
my ge profile gas locked door is blimking after I perform a self clean for the 1st time and I tried... (More)
Answer
I just did a cleaning cycle and the door will not open, oven is still hot...the lock seems jammed
Answer
the start button won't activate washer; have verified good electrical connection i understand there... (More)
Answer
Over does not light, stove top & broiler ok. GE XL 44
Answer
The oven and stop top comes on, but the glass stove top will not heat suddenly. Had to turn the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile Spectra JGBP90 Gas...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
