Question about Xerox Phaser 8500/DN Printer
Xerox Phaser Error Code 09,036.44:923
Just added ink for the first time to a Phaser 8560DN and have a mess on my hands.
Errors code is 09,036.44:923
I've pulled the inks out and re-added them to no avail. I think it's a jam in the red ink, but it must be the old one originally in there as I have removed the one I added.
Any may to open it so that I can get to where the jam is?
Any othe suggestions welcome.
    Novelist:
  • 125 Answers
Hi ddibert07:
I would recomend that you have a certified technician work on this problem for you. The Pins that the cables plug into are very sensetive, I know I'm certified with Xerox. But you can keep running the printer through the purge cycle and get rid of the ink. You may have to apply pressure to the magenta ink to force it forward onto the heater. To do that just fill the magenta (Red) slot with bald paper enough to close the spring loaded lid and purge the system. Power on then off to purge. Hope this helps.
pdouglasss
Posted on Jan 10, 2009
Xerox Phaser 8560DN error code 07,010,43
Sadly, Xerox says that this means "Power off the printer and contact support". Phaser 8560 Support Drivers
However, there is something about "opening the pivot plate", it's Greek to me, but google it and see if you can't reset the brain in the printer and get it back to life without an expensive service call.
Aug 23, 2014 | Xerox Phaser 8560DN Laser Printer
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
Apr 23, 2014 | Xerox Phaser 8560DN Printer
Error code 09,038.46:42291
As "mariolands" said, only use xerox brand ink, and make sure the ink stick is not broken. If after this, the problem continues you may need to replace the ink loader and clear the ISC Faults. For the 8560 the part number is 133K27771. Here is a video to show you how. The video will also show other similar errors and part numbers for similar machines. Hope this helps!
Just a warning for people buying aftermarket ink sticks. These really do harm the machine and void your warranty.
Dec 13, 2010 | Xerox Phaser 8560DN Laser Printer
09,008,43:167 error on an Xerox 8560dn
The error code 09,008,43 indicates the ink is not melting into the printhead. Raise the ink loader Top Cover to access the ink blocks and make sure they slide down properly. If this doesn't fix it you gonna have to call Xerox for service maintenance.
Nov 18, 2010 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser error code: 09,038.46:37640
The ink loader 133K27771 is probably defective
Whit
Item, Inc.
Jul 26, 2010 | Xerox Phaser 8560DN Laser Printer
Our Xerox Phaser 8560 is continuously printer a thick solid black line down the center of every page. The ink so thick you can peel it off. ERROR code 07,010.43:12217
That error means the head tilt restraint is out of place. It sounds like there is a problem with the print head. Either that or the wiper arm that cleans the printhead is bad. But I suspect that because of the errors present some of the wax may have spilled and is giving you trouble.
Sep 25, 2009 | Xerox Phaser 8560DN Laser Printer
My Xerox Phaser 8560DN has the following error code: 09,035.43:70089 - I know it has something to do with the cyan stick, but what is it?
Try changing the inkloader. That should solve it. If you want to fix it.. try cleaning all the peaces of ink that maybe stuck in the inkloader, take it off and clean it very good.
Jun 11, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser  8500/DN Printer Logo
618 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
