I picked up an allfine 7" mini netbook for my daughter, but it changes time as and when it wants, one minute it could be perfectly fine the next it could be January 1st 2065, or if ive gone online it may go back to 1935 on its own. Of course the online licences don't match and then i cant log into certain pages. This problem occurs when the battery is at full/half or quarter strength, it happens sometimes when i start it up or not. Any thoughts??? Treat me like a novice too (not overly technical). Many thanks
SOURCE: ACER NETBOOK - CANNOT ACCESS ONLINE COURSE MODULES AFTER*
It sounds like two possible problems - a browser problem or a website problem. To test if it is a browser problem, try downloading Firefox if you are using Internet Explorer. IE has problems with all sorts of things. Also check in "Help" top toolbar that your browser supports 128 bit encryption. Possibly you may have to install java or lower security settings, some sites require session cookies, to correct that simply lower the cookies to accept all. Usually browser problems of this nature will also not let you use secure sites such as online banking - if you can access those sites - probably your browser is fine and it is a website problem.
Some sites that are interactive using Joomla or Mambo based CMS(content management systems) get a glitch where even after logging in, you must login a second time in order to do anything, the copyright tag at the bottom of a page should tell if it is that type of site. If so contact the web admin of the problem.
SOURCE: I bought my daughter and son each a 7
1. it seems there is some manufacturing defect in the electric wiring of that laptop. take it back to the dealer and replace it (it's still in warranty)!
2. you should check the electric port where u plugged ur charger using any other equipment, like mobile charger!
Forgot to mention it is running on Windows CE6.0
Still no answers out there???
unfortunately not new, so not a deal of help...
is it possible to reload the windows? eliminating that at least
