Question about Air Tools & Compressors
Main sjsn bnbv j jkjj
  • futureloginn
    futureloginn Nov 15, 2008
    what you want to ask
    Sergeant:
  • 183 Answers
If you keep them oiled, then you shouldn't have any. I suggest marvel mystery oil. It's what I use on mine and I've had some of them for 15 years and use them regularly.
Posted on Apr 24, 2009
SHARP AR5620SL CODE L4
  • Code: L4 01
  • Description:Main motor lock detection. The main motor does not rotate. After rotation of the main motor, the motor lock signal is detected for 1 sec or more. During rotation of the main motor, the motor lock signal is detected for 1 sec. When the main motor is stopped, the motor lock signal is not detected for 5sec or more. (Though the motor is stationary, it is judged as stable rotation.)
  • Causes:Main motor unit abnormality Improper connection or disconnection the main motor and the harness. MCU PWB abnormality
  • Remedy:Use SIM 25-01 to check the main motor operations. Check connection of the main motor harness/connector. Replace the main motor. Replace the MCU PWB.
Sep 08, 2017 | Sharp Office Equipment & Supplies
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
What year is this engine? and ci
From this chart - I think you may be misreading the number - 3970010 is possibly the actual number: Which makes the engine pretty old 68-72 350 V8 - 4 bolt main. I included past this number so that you can see that the number you posted doesn't actually exist. And thus my conclusion that the 9 is most likely a 0. Hope this helps. 3970010 350 69 Corvette late 69,4 bolt main 3970010 302 69 Camaro Z/28,Late 69, 4 bolt main 3970010 350 69-79 Truck 2&4 bolt main 3970010 350 69-79 Pass,Chevelle,Camaro,Nova,MonteCarlo 2&4 bolt main 3970010 350 70 Corvette 300,350,370 HP 4 bolt main 3970010 350 71 Corvette 270,330 HP 4 bolt main 3970010 350 72 Corvette 200,255 HP 4 bolt main 3970014 350 69-77 Pass,Chevelle,Camaro, Nova,MonteCarlo 2 or 4 bolt main 3970014 350 69-79 Truck 2 or 4 bolt main 3970014 350 72 Corvette late &undefined;72,200 HP,255HP 4 bolt main 3970020 307 68-73 Pass,Chevelle,Camro, Nova 3970020 307 69-73 Truck 3970024 307 69-73 Pass,Chevelle,Camro, Nova,Truck 3992386 327 68-69 Pass,Chevelle,Camro, Nova,Truck Large Jounal
Oct 13, 2014 | Cars & Trucks
My 200 amp braeker(main is tripped and wont reset. What should the incoming voltage be???
Don't mess with main breaker if you're not qualified.
Wires on main breaker are Hot even when main is turned off.
The only way to turn off main is to pull meter.
1) There are 2 Hot wires that connect to main breaker.
Each wire is 120Volts, and each 120V line is 'out of phase' with the other.
Two out of phase 120V lines create 240Volt circuit when they are wired together.
Read more on links below.
2) It sounds like your main breaker needs to be replaced, unless total of all circuits exceeds 160 amp. Turn off small circuit breakers and try main breaker again. If main resets, then turn small circuits back on one by one. Your main may still be bad.
http://waterheatertimer.org/How-to-replace-main-circuit-breaker.html
3) Here are more links that explain electric wiring.
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on breaker or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 21, 2011 | Cutler Hammer 200 Amp Circuit Breaker...
My action replay dsi turns red when i turn it on
ok it took me like 2 hours but I read the whole manual at the back page it says if anything like this happens you'll have to reset the system through the ar pc manager what to do exactly is in the manual the
connect ar to pc
load the code manager
right click on the program in the top lerft of screen
choose about action replay from the pop up menu
click on the reset action replay button
note: you will lose all codes on the system but it should work
Oct 06, 2009 | Nintendo DS Lite
Niko OTP-3211W 32' Mainboard Needed
We don't do email on Fixya and no idea who Jerry is. Keep all replies in the same post by clicking COMMENT under the name of the person you are replying to. Fixya gets 7 million questions a year, so the likelyhood of 'Jerry' seeing are impossible.
Here are your mainboards, 50 bucks.
Niko OTP-3211W TV Parts - ShopJimmy
www.shopjimmy.com/niko/otp-3211w
Niko 21VT3MB0224 (DA0VT3MB6F2) Main Board for OTP-3211W. $46.95. Part number is found on sticker. Set In-Stock Alert · Niko 24VV3EB0003 (DA0VV3TH2B2) PC Board. Out of Stock. Black Friday Deal. Cyber Monday Deal ...
Niko 21VT3MB0127 (DA0VT3MB6F2) Main Board for OTP-3211W
www.shopjimmy.com/niko-21vt3mb0127-main-board.htm This Niko 21VT3MB0127 (DA0VT3MB6F2) Main Board for OTP-3211W (21VT3MB0127) works for these TV models: Niko OTP-3211W.
NIKO 21VT3MB0224 Main Board for Otp-3211w ' eBay
https://www.ebay.com > ... > TV Boards, Parts & Components Find great deals for NIKO 21VT3MB0224 Main Board for Otp-3211w. Shop with confidence on eBay!
Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit ...
www.ebay.com/itm/Niko...OTP-3211W...Main-Board-MotherBoard...-/28218366183... US$49.99 - ‎In stock
This main board was pulled from a working TV with a broken screen, please refer to the pictures. The last 2 pictures are of the TV this was removed from. This sale is for the Main Board and cables shown. I only accept Paypal. Paypal payment must be made within 2 days of end of sale. I will ship within 3 business days of ...
NIKO MAIN BOARD 21VT3MB0224 REV:F FOR MODEL OTP-3211W ...
www.ebay.com/itm/NIKO-MAIN-BOARD...REV-F...OTP-3211W-/172511137409 US$39.95 - ‎In stock
WE TEST ALL OUR PARTS AND GUARANTEE THEM NOT TO BE DOA (DEAD ON ARRIVAL). IF YOU EXPERIENCE A PROBLEM WITH THE PART YOU RECEIVED PLEASE CONTACT US WITHIN THREE (3) DAYS OF RECEIPT AND WE WILL WORK WITH YOU TO CORRECT THE PROBLEM EITHER BY EXCHANGE ...
Amazon.com : Niko - Niko OTP-3211W Audio Board DA0VV3AB2C9 ...
https://www.amazon.com/Niko-OTP-3211W-Audio.../dp/B00SVM5OR8 TV Brand: Niko TV Model: OTP-3211W Part Type: MAIN BOARD Board Numbers: DA0VV3AB2C9, 23VV3AB0004 Part Number: 23VV3AB0004 Specifications: Look for 23VV3AB0004 in your part to verify part number and compatibility. Other Specifications: Part number can be found on the sticker. This board has been ...
Main Board Otp ' TV Repair Components For Sale
https://tvrepaircomponents.pw/niko/sale-main-board-otp__samsung_power.html
6 days ago - Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit. $45.99. Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit. Niko 32" OTP-3211W. Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit. $49.99. NIKO MAIN BOARD 21VT3MB0224 REV:F FOR ...
Otp Niko Main ' TV Repair Components For Sale
https://tvrepaircomponents.pw/niko/sale-otp-niko-main__samsung_power.html
6 days ago - Up to 90% off brand name Tv Part only from your leader in online shopping including discounts on niko, niko main, board niko main, niko main otp, board otp ... Niko 32" OTP-3211W 21VT3MB0224 Main Board MotherBoard Unit ... Niko 32" OTP-3211W 21VT3MB0216 Main Board Video Motherboard Unit.
Niko OTP-3211W Main Board DA0VT3MB6E4 21VT3MB0224
www.myshoptvs.com/.../7058-niko-otp-3211w-main-board-da0vt3mb6e4-m9204.ht... Find the best TV part Niko OTP-3211W Main Board DA0VT3MB6E4 21VT3MB0224 at the lowest price online.
22VV3IB0018 Niko TV Module, signal, DAVV3PI12C4, OTP-3211W
www.tvpartstoday.com/22VV3IB0018-Niko-TV-Module...board.../22vv3ib0018.htm Part Number: 22VV3IB0018. Board Numbers: DAVV3PI12C4. TV Models: OTP-3211W. Type: Signal board. ... 22VV3IB0018 Niko TV Module, signal board, DAVV3PI12C4, OTP-3211W Email A Friend ... MODEL NUMBERS: OTP-3211W PART TYPE: Main Board TV TYPE AND SIZE: LCD, 32" MFR PART NUMBER: Niko ...
Niko OTP 3211W main board Google Search
Dec 30, 2017 | Niko OTP-3211W 32 in. LCD Television
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Air Tools & Compressors Logo
145 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
