Question about Sharp R-203BW Microwave Oven
My Sharp R-248h 800w microwave is not heating up any food items.
Hi, I have bought this microwave from singapore. It is not working, we have touchpad control problem, finally i solved that issue. Now it is not heating up any food items, even though i can see the light is glowing and the plate is rotating inside. I want to know is there any way i can fix the issue or check the issue myself. Thanks Jayakumar
  • saleem_7 Dec 02, 2007
    i had brought Sharp r-248h model sharp microwave oven. it was some 5 years 2003 back, i tried using now in nov 07. it did not hat as expected.. suspecting i am missing some instructions.. can anyone help is or share the User manual in english.
    Thanks,
  • Sharp Master
  • 9,156 Answers
That sounds like it would be a 220V 50Hz model. I would assume you're using it with the correct power source or if needed, the right power transformer and/or adapters. I'm curious how you solved the touchpad control problem? When troubleshooting, I always first check an area that was worked on before if I know about it. That being said, the most common causes of the problem you describe are: - defective door switch (probably the upper one) - defective door switch mount - loose and tarnished connection at the FA terminal of the magnetron (disconnect, tighten, burnish, and reinstall) If you have sufficient experience and/or information, you can do it yourself, but I a microwave uses and produces voltages that can be instantly lethal. These areas can be safely checked if the oven is disconnected from the wall and the high voltage capacitor is properly discharged. Information on discharging the capacitor and testing these parts is available from various sources on the Web. Door switches can be obtained from a local appliance parts store. Good luck and be safe.
Posted on Nov 13, 2006
SOURCE:
How do I get the heat to work?
Hi Marc, there is no 'heat' per say with microwave ovens as one would find in a convection oven. Microwave ovens operate by generating electromagnetic fields (within the microwave band) that causes water molecules in the food item to vibrate/rotate creating friction/heat - within the food item as opposed to the surrounding space (this would be convection)
Oct 26, 2014 | Oster Microwave Ovens
Sharp microwave r95stm not heating
This a common problem, the likely cause is a bad magnetron "heats food" and is the heart of the microwave oven, if the item is five years or more, cheaper to replace.
Mar 05, 2012 | Sharp Microwave Ovens
Sharp R-340H Microwave has power but does not heat food. Carousel working.
The magnetron is the likely problem, "heats food" the other two items to check is the high voltage capacitor and diode. It usually is cheaper to replace.
Apr 06, 2011 | Sharp Microwave Ovens
Oven does not heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | Sharp R-1480 Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
My microwave sounds like its working but is not heating food
More than likely, what has failed is called a "Magnitron" and you can find them online and replace, you may have to take your unit out verify what model it is, and sizes. but yes fixable.
Nov 09, 2009 | Microwave Ovens
Our microwave (GE) not longer heats food items.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Sharp R-203BW Microwave Oven Logo
313 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
