Question about Philips Televison & Video
I have a philips 23pf5320/28 tv when i turn it on i just get a blank white screen with an occasional yellow tint of color
  • dbauer05 Nov 12, 2008
    its only a few years old its an LCD ( no picture tube)
  • 734 Answers
How old is your TV? May be you will have change your Picture tube.
Posted on Nov 12, 2008
    Sergeant:
    Novelist:
  • 196 Answers
Remove the power cord of the tv from the electric outlet for sometime.then again plug in it gets mostly resetted and becomes proper.
  • mmechanics Nov 12, 2008
    if resetting does not solves your problem.
    then
    this is a very common problem. your optical engine in the tv is bad.
    this is a 900.00 part.
    feel free for further assistance.
    thanks
Samsung DLP tv white color turned to yellow
go into menu reset picture settings to default
red , tint or gamma is off
Nov 15, 2016 | Samsung Televison & Video
YELLOW TINT ON SCREEN MITSUBISHI TV MODEL WS 55313
The WS is a picture tube type rear projection first produced as a 2003 model year set.
A few questions and then a offer if needed.
Did this happen suddenly or after a power loss?
By reboot do you mean the recessed reset button on the front of the set?
I will presume if you turn color off completely the screen is some other color than black and white?
the offer: have you tried the Option menu this set has hidden, I can explain if needed.
Dec 11, 2012 | Mitsubishi WD-52525 52" Rear Projection...
I am noticing a yellow tinted circle in the middle of my screen. It is noticible when the screen is blank between channels and you can see anything white on the middle of the screen is tinted yellow. Do...
Is it an LCD tv or CRT ?
If CRT try moving the TV to a different location as the magnetic field from another device or even the earth can effect it.
The power switch (full power on) would normally demagnetise the screen.
If its an LCD has any object hit the screen, it could be a child's toy or knocking the screen can bruise the panel.
Feb 05, 2011 | Televison & Video
Yellowish tint on my rear projection
IF you turn the color off and go to a black and white channel, a yellow screen indicates something and just confirm this so I am able to help.
SD TECH
Nov 06, 2010 | Philips Magnavox 51MP392H Rear Projection...
The image appears to have excessive yellow tint. and there are no images coming thru the blue projector
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Philips 55PW9363 55" Rear Projection...
BLUE TINT ON MY SCREEN
Philips tv's have always had this problem. Between the picture tube and focus lens there is a layer of coolant fluid. The coolant fluid, over time, will break down and turn a brownish cloudy color and it usually starts with the blue. Something to do with the color frequency. Have a good repair shop check it out and if the fluid is the problem have them change all the fluid in all 3 picture tubes (there is a red, green and blue tube). Don't feel bad, like I said all the philips projo's had this problem. Thanks
Oct 29, 2009 | Televison & Video
Color Tint on CRT Philips 9P60349103
Return it to the "friend" as defective.
Nov 26, 2017 | Philips Televison & Video
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
