Question about HP Computers & Internet
Checking file system on C: The type of the file system is NTFS. I turn on my hp pavillion ze4400 and get a blue screen with this message: One of your disks needs to be checked for consistency. You may cancel the disk check, but it is strongly recommended that you continue. Windows will now check the disk. CHKDSK is verifying files (stage 1 of 3)... file verification completed. CHKDSK is verifi\ying indexes (stage 2 of 3)... 1 percent completed. It stops there and nothing else changes after a day of running my laptop and waiting for indexes to be completed. I dont know what to do.
  • HP Master
  • 1,879 Answers
You got a bad disk
Get an external hard drive.
Reboot and Cancel the disk check for you to log-in to Windows.
Back-up all important data.
Once data is safe, open My Computer and right-click on you C: drive then choose Properties.
Click on the Tools tab and click the Error Checking button then select all options and follow on-screen instructions.
Posted on Nov 12, 2008
Error message stop 0x00000024
which operating system ?
If you get the Windows blue screen, you can determine which stop code you have and determine what you need to do in order to get your computer back to working correctly.
First, make sure that you have this error code - Stop 0x00000024 or NTFS_FILE_SYSTEM. This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives. One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log. Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
Finally, in Check disk options, select the scan for and attempt recovery of bad sectors check box. You can also select the Automatically fix file system errors check box.
http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/windows-xp-blue-screen-error-message-0x00000024/9d6475ed-dc42-4fa7-a2a2-506c42f6ee63
Feb 24, 2013 | Computers & Internet
My brother hit the reset button on the bottom of our HP Pavillion ZE4400 now, a screen comes up and says "operatins system not found" what do i do
you have to insert the system software installation disc that came with your laptop, or go buy one or order it for free online. You reset everything now the laptop has no operating system to run off.
Feb 24, 2011 | Computers & Internet
I turn it on and it goes to a screen that says: "Checking file system on C: The type of the file system is NTFS. volume label is s3A5802D002. one of your disks needs to be checked for consistency. You...
the time it takes depends on the hard drive size but you push esc or enter as these are primary keys or let it start go have a coffee then come back to it.
Oct 06, 2010 | Toshiba Qosmio G25-AV513 Notebook
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
At the command prompt type
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I reciently installed a bigger HD and now I get the"blue screen from hell"!! How can I get it to boot on the new HD?,Ray
did you format the hard drive first?
typically you need to format the hard drive using the NTFS file system before you install your operating system.
does your bios recognize the hard drive?
make sure your bios detects the hard drive.
can you boot your computer in Safe Mode? If so, do that and use your error log to find the specific cause of the blue screen,
lastly post the blue screen error message on here to get a better answer.
Nov 26, 2009 | HP EliteBook 6930p Notebook
Intalled vista basic on my Hp pavillion ze4400 my
You will need to go to HP.com and download your VISTA drivers for video.
And you should check your device manager for flags, as you may need to get other drivers as well.
Oct 25, 2009 | HP Pavilion ze4400 Notebook
Compaq presario V2000 laptop
D: is a partition on your main drive C: NTFS = New Technology File system.
Feb 22, 2009 | Compaq Computers & Internet
LAPTOP
Reboot it and keep pressing F8. Select boot to Safe Mode.
-Try to uninstall the last application that you installed.
-Try to do system restore as well
Jul 26, 2008 | Gateway MX6912 Notebook
Toshiba tecra 9000 wont start
Blue screens are generally operating system failure. You will need to reinstall your XP home. Format the drive NTFS, instead of FAT32. If you have any problems during or after the reload, then the hard drive is the failure and will need replaced.
Jul 01, 2008 | Toshiba Tecra S1 Notebook
Computers & Internet Logo
139 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
