Question about Whirlpool Washing Machines
Shaking during rinse
My washer shakes and vibrates too much. I already replace the springs. still same problem. hope you can help me.
thanks ormirez
    Sergeant:
    Novelist:
  • 196 Answers
Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Posted on Nov 12, 2008
Washer shakes and vibrates very loud when on spin and rinse cycles. Washer is level, the inside baskest has lots of play in it. Could that cause this problem
you can pick up the drum to set it back in place .sometimes that will shake your washer. be sure to not over load or unbalance the washer. hope this works 4 ya
Sep 18, 2011 | Washing Machines
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
Mar 27, 2011 | Amana Washing Machines
Kenmore he2 washer shakes violently
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2009 | Kenmore HE2 Plus Front Load Washer
I have an atlantis serial # 16100596av the washer shakes and vibrates sometimes excessively on the rinse as well as the spin cycle. i hope this is an aesy solution!!
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Apr 12, 2009 | Washing Machines
VIBRATION
It should have should leveling legs under it. Screw upwards all the legs. Means your washer is now at its lowest level. Shake the washer with both your hands. Adjust the leg where the shake is, upwards or downwards to stop the shake. When the shake is totally removed, lock the legs with the check nut above the leg; meaning there 2 nuts, one above the leg & one under. You most probably have to check out your corner of the machine, where the problem lies. It is important that you lock the nuts or the problem will recur.
Apr 01, 2009 | Maytag Washing Machines
Washer shaking
first make sure the shipping bolts were removed from the machine, then make sure it is level, then if it still shakes, take your fist and hit it on your head... jk, if you have it on a wood floor, or your floor isnt 100% sturdy, you cant do anything about it besides using anti vibration pads. they wont do that much tho.
Feb 12, 2009 | LG WM-2077C Front Load Washer
Shaking uncontrollably during spin
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
EXTREME SHAKING DURING SPIN CYCLE
Dec 27, 2008 | Washing Machines
Washing Machines Logo
83 people viewed this question
Dan Webster
Dan Webster
Sal De
