Question about Motorola Mobility V600 / V620 Earbud Hands Free Headset
I think i broke it :(
A few days ago i was trying to charge my phone and i went to put the charger out but i didnt push the button down properly so when i pulled it out the thing that my changer goes into came forward a little bit so now it wont charge.do you know if its fixable or do you know if i can fix it? please help, thankyou xxx
Tip
Jailbroken iphone battery died
i fell asleep and forgot to put my iphone on the charger and the battery died... i put it on the charger the next morning and it wouldnt charge or turn on. it just had the battery icon with a red line in it with the little bolt underneath. i let it sit on the charger for a few hours and still got nuthing..i thought i was gonna have to connect it to itunes and restore it and lose my jailbreak...but i didnt...i just put my iphone into dfu mode, then took it out of dfu mode and put it back on the charger. after a few minutes the iphone turned back on and i still had my jailbreak and everything. i jailbroke on jailbreakme.com a few weeks ago. i dont think that site is up anymore... hope this helps somebody :)
on Sep 05, 2010 | Cell Phones
Battery wont charge
I had the same problem a few days ago. this could be because the battery is not connected to the cell phone properly (from dropping it or leaving the cell phone in the sun) and may need something, such as tissue paper or ordinary paper to be folded and put on the one side of the battery which is not connected and this will tighten the connection.
hope this helps
Feb 23, 2012 | Apple Iphone 2g 3g 3gs 8gb 16gb S
My iphone didnt charge and its not turning on. my laptop charger is open like the inside part to charge it,i use half of my iphone charger to try charge it the battery was almost dead after a couple trys...
Try doing a master reset by holding down the Home button (the button at the bottom with the square), and the power button at the top of the phone down at the same time until the power off command comes on, but keep holding until you see the apple logo come on then let go. This is a master reset. Then try charging it. let me know how that goes.
Feb 17, 2010 | Apple iPhone 3G
Envy charge port keeps breaking
Although today's electrinics are nicer to look at than things were 5 years ago, they're also more fragile. You must treat things like egg shells if you want them to last. I've had the same cell phone for 4 years, mi wife has been through 7.
Feb 17, 2009 | LG enV VX9900 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
Help!Phone does nothing!
Ok you need to replace that charger cos thats the one that is doing all the damage. Check your battery voltage if its below 3v then you need to rejuvenate it back to its original capacity. It will be ok good luck.
Jul 02, 2006 | Samsung VM-A680
Radio Communications Logo
29 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
