Question about Home
Pool pump won't shut off
Help. My pool pump won't shut off. It's on a timer but when either the timer goes off or when I push the control button manually, the pump just keeps running. The only way I can get it to stop is to physically cut the power to the pump. I don't know if I have a problem with the pump, with an electrical switch, or if maybe there is a pressure or obstruction issue causing this. I'm at work so I don't have the motor specs with me but I belieive it's a Pentair. I pulled the top cover and I remembere seeinig a Magnetek 9949 capacitor on top of it.
  • 4 more comments
  • astoller Nov 13, 2008
    None of the above are applicable. It's worked for 8 years and just had a problem now and the timer is fine (everything else on the timer works great).
  • dgbeas Dec 03, 2008
    I am having the same problem.
    Pump and timer have been working fine until yesterday, when I noticed the pump was running at an odd time that I knew wasn't programmed with the timer.
    I tried to manually switch the motor off, but the switch was already in the "off" position! The manual switch no longer has any effect on the motor. The only way I can turn it off is to cut power at the circuit breaker.
    I assume the timer needs to be replaced( it is obviously old )???
  • jerry196 Dec 30, 2008
    I have the a similar issue but with a little more info:
    I am using a pentair controller.
    I disconnected the freeze sensor...it still runs.
    I swapped relay feeds on the control board and it still runs.
    Any thoughts?
  • lillrider13 Feb 21, 2009
    I have a Jacuzzi 5' x 3' jetted tub. It has a 3 button control panel. The center button when pressed turns the jets on. When you de-press it, it normaly turns the jets off. The button is stuck in the downward position and the tub had to be turned off at the breaker. After unscrewing the 6 screws that hold the panel plate on, and taking a blade and positioned it between the plate and the tub to release any adhesive / silicone / or gasket, the plate still won't come off.
  • em_at_602 May 03, 2009
    The pool pump would not shut down with manual switch on timer. I replaced timer and wired it the same way the old one was when it worked. The new timer still does not shut down pool pump with the manual lever. Only shuts down from circuit breaker. I appreciate your help.
  • davekb May 22, 2009
    just replace a 4 way switch on a 230v pool pump. There was power to old switch but not to motor. when i hooked up new switch pump starting running but when I shut switch off pump keeps running. Is new switch possibly bad. I have two wires coming from 50 amp breaker in basement thru conduit. One wire is orange and the other is blue. two yellow 14 ga wires run to the pump motor and there is a green ground wire from basement too. I hooked them up the same as the old switch. Why would it still be running. I moved the wires aroung to no avail. thank you
1) timer is on over ride
2)timer faulty -replace timer
3)wiring done incorrectly -power to pump is still present when timer goes off
Posted on Nov 13, 2008
I HAVE A JACUZZI TUBE AND RECENTLY IT WONT SHUT OFF. I AVE TO SHUT IT OFF AT THE CIRCUIT BREAKER
Posted on Jan 30, 2009
Pro logic hayward pool won't shut off pump
The pool timer control needs to be replaced completely. It seems that the timer may work but the relay is perhaps shorted or shunted. It can not be reasonable repaired, thus replacement is the only answer.
Jan 11, 2018 | Hardware & Accessories
How do I turn off the timer on my pool pump so it won't come on
if you are using a hayward control panel, either change the timer or push the 'service' button once. if it is a seperate timer, turn off the breaker to the timer
Jun 13, 2014 | Hayward Pool & Spa
I want to know how to set the time on my swimmimg pool timers
Hello Gerhard
1) Unknown brand name pool timer, probably Intermatic:
Unknown if this is mechanical timer, or digital, or remote control, or air activated. Or if this is control center with circuit breakers and multiple timers to control heater, and pool pump, or if unit has firemans switch to turn pool heater off 20 minutes before pool pump, or if unit has freeze protection thermostat, etc
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
2) For Tork:
http://waterheatertimer.org/Tork-Pool-timers-and-manuals.html
3) Jan 2013.
Add a comment with model number or attach photograph and add any other information available for best possible answer based on specific product.
Jan 02, 2013 | Hardware & Accessories
My pool pump will not shut off. I can only shut it off with the breaker
Your contacts have stuck together at the relay in your controller, or in you timer. It needs to be replaced.
Oct 20, 2012 | Zodiac Jandy AquaLink RS All Button Wired...
What else could cause power to pool pump to shut off?
Check the timer clock, the timer maybe faulty or the time is incorrect.
Oct 13, 2012 | Hayward 1HP Super Pump II Inground Pool...
Turn heater for pool while pump in on, everything is fine, pool heats then when timer stops pumping, the heater will stop but the digital temp climbs,on display and eventually goes on the display...
When the system shuts down the water inside the heater collects residual heat in the heater. For most systems that have intermatic timers (yellow dial) you can get a fireman's switch kit that will shut the heater off about fifteen minutes before the pump goes off to let it cool down. If you have electronic controls you should have one built into the system and will just have to activate it.
No promises but this could cause problems with time.
Oct 30, 2010 | Sta Rite 200k Btu Nat Gas Heater Maxetherm...
Need to know how to backwash the pool filter
Depends ...
There are two primary valve styles ... a "multi-port" and "push-pull". Never change a valve setting with the pump running.
Multiport has a handle that goes around in a circle (only move it clock-wise). You should go to your pool place to identify this kind of valve and get new lables. Push-pull goes up and down. Up is filter - Down is back wash.
If you will study your system, some things will become evident to you .
Your pump pulls water from the pool through the pump ... out of the pump into the filter. Through the filter, back to the pool. You might be heating the water (would be after the filter) and you may be adding sanitiser (after the heater). One suction - two discharges (oh, the other discharge is to waste.).
Recap ... water out of the pool into the pump - out of the pump throuth the control valve to the filter - out of the filter to the heater then to the sanitiser then back to the pool.
Any help?
Thanks for your interest in FixYa.com
BTW ... I am a volunteer question catcher at FixYa.com. At my job, among other things, I am a Certified Pool Operator (CPO), certified by the National Swimming Pool Foundation.
May 14, 2010 | Pool & Spa
Heater for pool not responding
leave power off for about 15 minutes for a reset if still on check control panel heater relay may be stuck or faulty same goes for stat -if both are good most likely mother board is problem
Mar 05, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Intermatic Pool timer will not turn off... I have to shut off the pool pump at the breaker... Any suggestions on what the problem might be?
If the pool pump timer is not working, first look and see if the clock dial is moving, if not then you need to check the 120volt breaker that feeds it ,, then you would check the connections on the timer to be certain that they are correct.
Jan 18, 2010 | Intermatic Timer T12404R Pool & Spa...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Home Logo
2,334 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
