Question about Toshiba 35A44 35" TV
Black screen in middle of picture
When i turn the tv on the picture shows up fine and the sound is good but after about 5 seconds the pictutre has a black screen in the center of the picture. Its a 32 inch toshiba cinema series
  • 81 Answers
Go tothe menu, caption, take it off the text mode. this should solve your problem
Posted on Apr 07, 2007
SOURCE:
Plasma TV has a black uneven splotch in the middle of the screen
hmmm. sounds like the screen might be damaged. You might have to get a new one. But before you do that I would try leaving it off for a while maybe a few hours or so and see if that helps.
Jul 10, 2017 | Televison & Video
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Mar 07, 2009 | Panasonic PV-C1322 13 in. TV/VCR Combo
TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 07, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Westinghouse SK32H240S TV will not show picture...
Some solutions to this same problem were posted here, hope this helps.
Nov 22, 2008 | Westinghouse SK-32H240S Television
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
Picture getting small blacking out
Yes you sound like pincushin is failing on you. Soon it will knock out horiz. output caps and Diodes. Needs repair soon.
Apr 25, 2007 | RCA F35673MB 35" TV
BLack box in the middle of my screen?
iv'e run into this before, you have closed caption text 1,2,3 or 4 on. this is different than the normal "cc" cation. just go into your menu & turn off closed caption.
Dec 27, 2006 | Sharp 25L-S100 25" TV
Toshiba 35A44 35" TV Logo
161 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
