Question about Konica Minolta bizhub C450P Laser Printer
I have an c-1183 error on my Konica minolta bizhub c450
Is there a way i can bypass the error so i can continue printing.....it was printing fine and then the part that the paper is recieved at the end got jammed and it went to that error....then we went and unjammed it and it is still in that error mode and we can not bypass it in any way.
  • Dan
    Dan May 11, 2010
    Bizhubs can be tricking in clearing some errors.
    I am assuming you powered the machine off and back on already.
    Try opening and closing the front panel door. For some reason this clears out some errors.
I have an c-d 204 error on my Konica minolta bizhub c450
Posted on Feb 23, 2010
    New Friend:
  • 51 Answers
Hi u have finisher and one of the finish trey are not straight.
Posted on Aug 30, 2009
  • 24 Answers
C1183
Elevator motor ascent/
descent drive failure
• The elevator tray lower limit sensor (PC13) is not turned ON
even after the set period of time has elapsed after the main
power switch is set to ON.
• The elevator tray home position sensor (PC11) and elevator
top face detection sensor (PC12) are not turned ON even
after the set period of time has elapsed after the elevator
motor (M11) is energized.
• The elevator tray does not stop at the position for the specified
tray after the elevator motor (M11) is energized (beginning of
descent operation) and the elevator tray lower limit sensor
(PC13) is turned ON.
• The elevator top face detection sensor (PC12) is not turned
ON even after the set period of time has elapsed after the elevator
motor (M11) is energized (beginning of ascent operation)
when paper is being fed out.
Cannot be bypassed it is a fail safe and needs repairing then resetting
Posted on Jun 25, 2009
Put the copier off then disconect the finsher cable then conect the power &put copier on if it work proper conect finisher cable
Posted on May 06, 2009
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Minolta C450 fault code C-2656
konica minolta bizhub c450 error code c2656
Feb 09, 2013 | Konica Minolta Office Equipment & Supplies
ERROR CODE LIST FOR C450
Go to service mode and click on counters, then select Service call counter, there you will find the complete error code list for bizhub c450.
Dec 06, 2012 | Konica Minolta bizhub C450P Laser Printer
Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Mar 11, 2009 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta bizhub C450P Laser Printer Logo
1,968 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
