Question about Compaq Presario Notebook
PC-Centrino-Duo-M200, headphone,mic and camira are not working
Hallo,
my pc headphone, mic and the camira are not working plz kindly help me to solve this problem.
my pc is windows vist, toshiba, core 2 dou insid.
with lots of thank.
Sir no carmra&headphone
Posted on Nov 14, 2008
  • devi lal Nov 14, 2008
    plz give me cq40-133tu driver URL
How do i free 8mb in Sandisk Sansa M250 i formated but the same result happens plz help me!!!!
SanDisk tech support recommends formatting the m200 series in both MSC and MTP modes to completely clear out all work areas,"fragments" and residual data. The m200 has a very basic Operating System that doesn't have a defrag option. According to tech support, the m200 needs formmating occasionally to keep it working smoothly. I learned that formatting will also clear up intermittent hang-ups. I format mine each time I reload it.
Format in MSC Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then MSC.
Connect the m200 to the PC via the USB cable
Right click on the "Start" button.
Left click on "Explore"
Find the m200. It will show as a hard drive, for example: "SANSA M250"
Right click on the m200 device and select "Format"
After formatting is complete, click on the "Safely Remove Hardware" icon on the System Tray and stop the device
Disconnect the m200 from the PC.
Format in MTP Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then Auto Detect.
Connect the m200 to the PC via the USB cable.
Find the m200. This time it will not show as a hard drive but as a music device, for example: "SanDisk Sansa m250"Note there is no drive letter in MTP mode.
After formatting is complete, disconnect the m200 from the PC. There is no icon to stop the device.
Your m200 device is now formatted and ready to reload.
By the way, MSC mode is mostly for use with other than Windows XP computers. If you are using WinXP and Windows Media Player 10, you might consider using MTP mode and WMP to manage the m200's.
Source: http://forums.sandisk.com
If i was helpful, kindly do Rate!
Regards.
Jul 28, 2009 | SanDisk Sansa m240 MP3 Player
IBM ThinkPad T41, Upgrade my Intel Centrino Processor
make sure that the socket supports your new max Intel.
Feb 04, 2009 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 Intel Centrino Upgrade to Intel Core 2 Duo?
According to system specs your system is not compatible with the Core 2 Duo or Centrino Core 2 Duo. To upgrade to those chips you would need to replace the motherboard with one capable of running those chips. If you decided to do that you would almost surely need new RAM as newer boards use newer technology. By the time you did this the upgrade would not be cost effective. Hope this helps & please remember to rate my answer. Thanks.
Feb 03, 2009 | IBM ThinkPad R40 2722 Notebook
Audio device
Hi there
If you go to the HP support website, enter your laptop model you can download the audio drivers from there
Support site here
http://welcome.hp.com/country/uk/en/support.html?pageDisplay=support
Good luck and kind regards
Jan 06, 2009 | HP Compaq Presario V5000Z Notebook
Download driver audio for laptop hp
plz download the drivers from the manufacture website
Jun 28, 2008 | HP Business Notebook 530
Centrino
Hey maria22,
The word "Centrino" is a label used by the company Intel to describe specific configurations of wireless networking hardware, motherboard components and processors in some computers. It should not have any kind of negative meaning, and may generally be viewed as a marketing tool or a description of a model line.
When computer manufacturers only use a portion of the Intel-approved Centrino-qualified components in their computers, those computer models may carry a different label such as Celeron, Pentium M or Intel Core 2 Duo.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 11, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Microphone and headphone problem
Usually when you double click the speaker icon in the system tray you'll see the volume settings for all your devices. On microphone there is usually an check box for mic boost. Set those to mic boost. Then check that all the sliders in the volumes are one increment below the top but maximum for Wave. Then set the master volume to a comfortable loudness This you can access by a single click to the speaker icon.
Next, you can go to Control Box, click on Sounds and check the settings for speakers/headphone and also for recording where there is usually a routine for checking the recording settings via your microphone made available to you.
Please do not hesitate to ask me for more information and kindly be specific if you can. I'm here to help and will get back to you in a reasonable period of time.
Hope this fixed your problem and thanks for using Fixya.
Regards,
Worldvet
May 26, 2008 | Compaq Presario 700 470024-192 Notebook
Using Skype - Intneral mic no longer works
Its due to your internal laptop MIC's failure! Plz check at any Compaq Service station! Becoz its internal hardware error! Becoz there r no seperate drivers for MIC! If your speakers are working great then MIC should work or else try to get repaired it!
Dec 02, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario Notebook Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
