Question about HP PSC 1610 All-In-One InkJet Printer
Error msg below
How do i solve this error on my all-in-one HP printer6210
error 0x031e4dd6798:lib_barracud
    Scholar:
  • 181 Answers
Its the main board error.that needs to be replaced.it will be very costly .
sometimes unplugging the printer for sometime and then replugging it helps.u can try that before taking any descesion.
Posted on Nov 13, 2008
How to solve scanner error 5 in HP LASERJET 3055?
The stepper motor controlling the scan arm is defective. Replace motor or entire unit.
Aug 07, 2014 | HP LaserJet 3055 All-In-One Printer
Describe your Officejet Pro L7680 All-In-One Printer Problem I get the error message that my black ink cartridge is empty. I replaced it with a new one and still had the error msg. I went through the...
Hi rainbow1785,
To correct this issue, please follow the steps below. With the new cartridge inserted, reset the unit to its factory setting.
1. Unplug the power cord from the HP All-in-One.
2. Wait for 20 seconds.
3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
4. Release the buttons after the HP All-in-One starts up.
5. The HP All-in-One will now be reset to factory defaults.
Hope it helps.
Thank you for using FixYa.
Aug 23, 2011 | HP Officejet Pro L7680 All-In-One Printer
Error msg. "50.1 Fuser Error" Turning printer
Hello Pls replace the fuser with new one your problem will be resolved if problem persists then replace the dc controller bord.
Oct 28, 2010 | HP LaserJet 8150dn Printer
Laptop suddenly turn-off with error msg
Sounds like the System Bios Settings changed from SATA to ATA. Change to SATA.
Good Luck
Mar 11, 2010 | HP Computers & Internet
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
BIJ 2800 unable to print as error "-00D4-c3f9 LIB MICCI.DL212" error appears
HP All-in-One Products - Performing a Partial Reset of the All-in-One Introduction There are times when a partial reset may be required to restore the all-in-one to proper operation. A partial reset does the following:
  • Reset the user settings to the factory defaults.
  • Reset the language and country/region settings on some models.
Performing a partial reset Follow the steps below to perform a partial reset of the all-in-one:
  1. Unplug the power cord from the all-in-one.
  2. In the table below, locate the button combination for your model.
      NOTE: If your all-in-one model is not listed in the table, your model does not have a partial reset option.
  3. Press and hold the button combination for your all-in-one.
  4. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one starts up.
Product family/model
Button press
HP PSC 2500 series
Press and hold # and 3 while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+ ) instead of # .
Apr 21, 2008 | HP PSC 2355 All-In-One InkJet Printer
Error msg status 1
sounds like a communication error, are you wireless?
try connecting direct.
Feb 05, 2008 | HP Photosmart C6180 All-In-One InkJet...
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Scanner error 6
in my network i have hp M1005 printer always i'm getting this msg "scanner error 6 turn off
then turn on"
when i make turn off and turn on again same msg comming
how can i solve this problem...
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP PSC 1610 All-In-One InkJet Printer Logo
283 people viewed this question
Ben Johnson
