Question about Whirlpool Calypso GVW9959K Top Load Washer
Trouble starting Cycles
I am having trouble getting the machine started after pushing the select washer buttons.Right now the regular washer button is on and will not go off,I can keep pressing the casual button on and off rapidly and finally get it started only on that cycle, no other choice,if I press the cancel/stop button it reverts back to the regular wash button light, the stop button does not turn off all the lights. I ordered and replaced both boards, and the same problem exists. Sure would appreciate any help. thanks, Jonsey
  • Ralph Jones Nov 14, 2006
    I really appreciate your trying to help, but that does not seem
    to work,it might if I could get the machine buttons off to start
    any cycle, as I mentioned, the regular wash button stays on, I
    don't have a choice to make a change,I tried desperately to do
    what you suggested but again nothing happens by pressing any of
    the buttons including the regular wash button that stays on.I
    can't make anything work. With both new electronic boards you
    would expect everything would be fine. Any further suggestions
    would be greatly appreciated.
    Ralph
    President:
  • 878 Answers
Jonsey, sounds like you have a keypad issue here. Do this test: press the following keys in this order soak-cycle signal-soak-cycle signal. If done right the display should show dt. Now press start, all the led's will light up. Now test them by pressing each one, you should hear a beep for each one. If some of them are not responding, check the P-11 and P-12 harness on the control board. You can also put this machine in the automatic test mode by pressing the keypads in this order; soak-soil level-soak-soil level. The display will start counting down from 99 to 0 testing different aspects of the machine. Any errors will be shown in the display. Catriver..post back.
Posted on Nov 13, 2006
  • Ron Marek
    Ron Marek Nov 14, 2006
    Slats, unplug the machine for 1 minute. If it comes back the same way check the key pad ribbon connection to the board. Also check the P-11 and P-12 harness connections. If these are ok, you are going to need the touch panel...Catriver..post back.
SOURCE:
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
My bosch nexxt 100 series washer will not start. The spin, wash and finish indicator lights flash simultaneously when try to start.
Make sure dial is switched to 'off'. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. If if doesn't work, do it again.
To get the clothes out if you are having trouble, open door manually. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off. The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Click helped if helped.
Mar 07, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
F+P 703 washer program codes green controller/keyboard
hi .now .push and hold START/PAUSE then push POWER button. then release both of them. now push POWER to turn the machine off then POWER to turn back on . now you can select your cycles. hope this helps, please reply 4 further help if needed
May 29, 2010 | Washing Machines
My compact front load washer won't work on most cycles
this is probably the push button panel or the timer
Aug 23, 2009 | Washing Machines
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Nov 29, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool front loading washer
I am having trouble starting the washer . I set the cycle on casual and press the start button and the washer sensor showed to " Done" instead of starting. I only bought it three months ago.
Jul 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
We purchased a GE front load washer in December 2007. Recently the boot had to be repaired. Now the machine is pausing when it gets to the rinse and spin or drain cycles. The pause light starts to flash. ...
ok Problem is not finding out the meaning of the pause button flashing but.......
you need to contact GE directly as this machine is under warranty.
Follow this link. GE APPLIANCE
If they do not help I will just contact me
Jun 05, 2008 | GE Washing Machines
Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Dec 26, 2007 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
213 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
