Question about Air Tools & Compressors
Copelemetic compreser hermetic
Iknow where c s r are and have plate to attach that holds thermal over load disc need to knowwhere the three wires from capacitor box go they are r w b and where do i get a new thermal disc
  • 70 Answers
United refrigeration sells the thermal overloads or grainger
Posted on Jan 09, 2009
Which color wires go to the herm, common and fan on the capacitor?
What brand condensing unit? Different brands use different colors.
Coleman not a common brand in my area, but logically the red should be common, large brown hermetic, and small brown is fan.
However to be sure you need to trace each wire to its termination.
Look at the wires coming out from the compressor and find which of the three wires corresponds to one of the three wires you are wanting to connect, then connect that one to hermetic. Then trace (probably the red wire ) and see if it connects to the contactor.If it does then connect that to common. Only one left will go to fan.
Apr 11, 2015 | Heating & Cooling
I have a Gibson dryer..It has a three prong plug
The National Electrical Code began requiring 4-prong receptacles for 220-volt residential circuits in 2000, but it doesn't prohibit you from using your older dryer with a 3-prong cord. Instead, it allows you to change the cord so that the dryer can be plugged into a modern receptacle, and the procedure isn't very complicated. Four-prong dryer cords, or pigtails, are available at hardware and electrical supply stores, and usually cost less than $20. To make the switch, you'll need a green ground screw to attach to the dryer body so the machine can be grounded by the ground wire.
1 Unplug the dryer and move it to an accessible spot. Unscrew the plate on the back that covers the electrical terminal with a screwdriver. You'll find the cover on the back of the dryer near the bottom of the machine at the point where the cord exits.
2 Loosen the three terminal screws holding the cord. Before you remove them and take off the cord, note the colors of the screws and the wires attached to them. The screws holding the black and red wires are brass and the one holding the white wire is silver.
Remove the ground strap from the silver terminal. It may be a small metal plate or a length of wire connecting the terminal to the body of the dryer. You may be able to pull it out with pliers, or you may have to loosen a screw to remove it. Its function was to ground the dryer, and that function will now be served by the ground wire on the new pigtail.
4 Insert the brass terminal screws into the ring lugs attached to the red and black wires on a replacement pigtail and the silver screw into the ring lug on the white wire. Drive the screws into the same slots from which you removed them and tighten them securely with a screwdriver.
5 Drill a 1/4-inch hole in the body of the dryer within reach of the fourth wire in the pigtail, which is green. Insert a green ground screw through the ring lug on the end of that wire, drive the screw into the hole and tighten it securely.
6 Feed the cord through the notch on the terminal cover plate and screw the cover plate to the back of the dryer.
Things You Will Need
  • Screwdriver
  • Pliers
  • Drill
  • 1/4-inch drill bit
  • Ground screw
  • 4-prong pigtail
Tip
  • There usually isn't room behind the cover plate to install the ground screw. If not, it's acceptable to attach the screw to the back of the dryer outside the plate.
  • Check the grounding with a multimeter before you plug in the dryer. Set the meter to ohms, touch one lead to the dryer body and touch the other lead to the ground prong on the plug. The meter should show less than 10 ohms of resistance.
Sep 12, 2014 | Dryers
How can I access the drain pump on a whirlpool WFW94HEXW washer when there is no lower kick plate? Does the whole front panel have to be removed including the door?
I just took apart my WFW94HEXW2 to clean the pump filter. Here's how: Take off the top panel by first removing the three screws attaching it to the back of the washer. Remove the detergent dispenser by pulling it out while pressing on the indicated tab. Take off the control panel by removing the four screws holding it. Two screws are Torx-20 where the detergent dispenser was. The other two are at the top of each corner and are 1/4 inch hex-head, as are all the others in this procedure. If you're careful you need not detach the wires from the control panel. Just take the wires our of the first two clips so you have enough slack to rest the control panel on top of the washer. Pop out the spring-loaded retaining wire that's holding the door bellows to the front panel. Remove all seven screws from the front panel, three at the top and four at the bottom. Again if you are careful you need not detach the wires to the front panel. Simply lift the panel off the retaining tabs and swing it out like a door with hinges on the right. Keep slack in the wires and securely prop up the front panel. You now have access to the water pump and filter. The filter unscrews so you can clean it and its holder. Reassembly is a matter of reversing the above steps.
Aug 07, 2012 | Whirlpool Duet: WFW94HEXW Laundry : Front...
Need the diagram of coil pack and the order of the how the wires plug into it from top to bottom
Just thought I'd let you know, All you needed to say is "firing order diagram for a 1998 Pontiac Bonneville 3.8L engine". Here it is:
Jan 10, 2012 | 1989 Pontiac Bonneville
My iron just stopped heating What can I do
You need to check the following for circuit contintinuity:-
The plug and wall socket
The leads, both the live and the neutral
The temperature selector (Thermostat)
The thermal fuses
The element
To do this testing you will have to strip the iron and get to the wire ends, the thermal fuses and the element terminals. (My guess is that it is the thermal fuses. They are little metal tubes wires attached and are usually insulated in white fibre glass tubing and attached to the element plate).
Feb 21, 2011 | Black & Decker Steam Xpress AS250 Iron...
LED light too dim, is there a brigher LED kit?
You need these parts:
- Low profile GU24 socket (Maxlite MLGSIIB)
- GU24 CFL bulb (Progress Lighting MLS13GUSWW6)
- Threaded pipe fitting, nut, washer
- 2 wire nuts
Here is how to fix it for a few bucks. You need a low-profile GU24 socket (Maxlite MLGSIIB), which is readily available in large mail order channels. You also need a GU24 compact fluorescent bulb (Progress Lighting MLS13GUSWW6) that is available through Home Depot mail order or other internet retailers. To my knowledge, these are the only parts that fit into the low-profile glass.
You'll also need a threaded pipe fitting and a proper size nut for attaching the GU24 base to the holder, both readily available at the ceiling fan section in HD. You'll also need a washer underneath the nut to hold the socket in place. Put your MacGyver skills to work.
To change the parts, uninstall the light fixture by unscrewing the glass, then removing three screws that hold the LED plate in place. Disconnect the LED wire connection and a larger white connection behind it. Then remove three more screws that holds the rest of the light fixture up and remove it from the fan.
Once on the desk, remove the back plate wire cover (3 screws) so you have access to the wires. Unscrew and remove the rectangular box (120v-12v converter), you won't be needing it any longer. Cut the black and white wires close to the module - you'll be attaching the GU24 socket wires to those wires.
Remove the LED circuit board from the plate by pinching the plastic standoffs and then pulling them out. Install the GU socket to the larger hole at the center of the plate using a pipe fitting, washer and a nut. Notice that it fits perfectly - it was probably originally designed to use this socket! You may need a washer that is the appropriate size to hold the socket in place. I also used a piece of bent paperclip underneath the washer to hold everything tight.
Remove the white thermal sleeve from the LED module wiring and insert it over the GU24 socket wires just like it was with the LED wire. This is to prevent heat damage to the wires when they touch the metal edges. Using smaller wire nuts, connect the black and white wires to the wires you cut off earlier when removing the 12v module.
Put everything back together, install the light bulb, and enjoy a much brighter light from this beautiful ceiling fan.
Jul 11, 2009 | Hampton Bay Dryers
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
I have bought 3 coffee pots from GE in 2 months all three have not worked now Wal-Mart cannot return our money without the receipt.
If they have failed after working a short while, the thermal fuse used in all drip coffee makers is failing and we have had exactly the same experience with another brand. Our toxic Chinese friends are making crappy thermal fuses along with about everything else.
Replacing these is impractical since they are in a small metal case, pointed on one end with two coaxial leads permanently attached. Further, they are welded  to wiring under the warming plate to the heating element. The area is too hot for solder and ceramic wire nuts have to be used to replace the fuse and these are tough to find anymore.
Bypassing them is a really bad idea since I know of one case where the thermal switch that causes the machine to cycle failed, the heating element melted through the aluminum plate on the bottom and set fire to a kitchen counter.
With the cost of labor being what it is, hardly any of these drip coffee makers are worth repairing.
Sep 28, 2008 | GE 106591 Coffee Maker
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
