Question about NEC VT460 Multimedia Projector
Dark Picture I have a VT46 that I purchased 2 years ago. I replaced the lamp about a year ago when the indicator came on. And everything has been fine since then until about a week ago when the picture began to get darker and darker. The lamp indicator/light has not come appeared. When I check the lamp usage in the menu, it's only 58%. So, I'm not sure what the issue is.
  • 115 Answers
If the Lamp condition is okay then check the FE lens just next to the lamp in the projector after removing the lamp out of prj. replace if that is burnt.otherwise replace Lamp.
Viren
Posted on Nov 27, 2007
I have a 50" RCA Scenium which I purchased in 2003. ($3000) I changed my third lamp yesterday...(the picture was getting dark after 3 years), and was very happy with the picture. Today, after about 2 hrs...
No, you do not have a bad circuit board, the problem is still from the lamp you fixed on it. Have it checked once again to see to it that there was no slight difference in the way you have been fixing it.
If you have a bad circuit board, there would be a complete alteration in the functioning of the television.
Since the problem has to do with the lighting and picture of the television, it has to do with either the lamp or t-com board, so check them both.
Take care
Oct 10, 2010 | Televison & Video
Have an 52HM95. Man.- 01-2006. Rent-a-center had the lamp (I believe) replaced when this happend the first time 3yrs ago. . It cost them around $200. Now 3 years later, its paid off, so, NEED HELP! (No...
The "LAMP" LED light indication on the front of the tv screen panel flashes or light up?The projection lamp was replaced 3 year ago u belive right?The average projection lamp life about 1 1/2 or 2 years.Withthin function in the tv and in used like 4 or 5 hours a day of tv viewing.Ur tv require a new projection lamp.
Sep 18, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
Tv brightness/vibrant
Most of the projection lamps are recommended to be replaced after 2 years. The older they get the more dim they will become. I would suggest replacing the lamp again. Some of the aftermarket lamps do not work as well as the factory replacement. I always spend the extra money and get one from Samsung.
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Tv will not turn on
For dark picture I need to ask one question, How long ago you replaced its lamp? one year, two years?
Picture brightness is depends on lamp in LCD rear projection (DLP) TVs and if lamp got weak in generating light, you will see dark picture.
I would recommend to replace lamp and buy Sony original lamp from Sony Accessories Store.
Required lamp part number is as follows..
F93087500 LAMP BLOCK ASSY XL-2400
and price is $200
Good luck.
Apr 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Dark display
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 11, 2009 | Computers & Internet
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Blue screen
I would suggest getting another optical block from the repair man. Apparently even some replacement blocks have had issues...
Jun 06, 2008 | Sony KDSR50XBR1 50" Projection HDTV
NEC VT460 Multimedia Projector Logo
194 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
