Question about Samsung Digimax i6 PMP Digital Camera
Camera wont stay turned on
Every time I try to turn my camera on (digimax i6) the shutter clicks open for two seconds then clicks shut.Does it when on charge,even bought a brand new battery-still the same problem.Is my camera junk now or do I have to spend more cash getting it fixed by a pro?Hopefully not-anyone help?
  • ansukman May 11, 2009
    Same problem with me, I have send it to repair and need to replace a main power supply board. Do anyone know other posibility solve this problem by ourself?
I had the same problem - found the answer on another forum: remove battery and memory card, press shutter button twice, replace battery and memory card, and switch on.
Posted on Nov 18, 2009
    Champion:
  • 225 Answers
If it still takes good pictures, do not worry about it. It could just be a startup test. If you cannot use your camera now, maybe you have a lens jam. Jams need to be fixed by pros.
Posted on Nov 13, 2008
Samsung Digimax D53 will not stay on
This is most likely a lens failure. Try contacting your manufacture if your camera is still under warranty. If not, try contacting your local electronic repair shop to get it fixed. Hope this helps!
Dec 07, 2009 | Samsung Digimax D53 Digital Camera
I have a digimax i6 pmp camera, when i try to charge it,the light on the charger turns red, then starts flashing orange and the camera will not switch on at all..can you help me?
sounds like you have a bad battery ... the charger has detected something wrong and shuts down with the error warning .. replacing the battery will likely resolve the problem ..
Oct 12, 2009 | Samsung Digimax i6 PMP Digital Camera
Camera turns off when shutter button is pressed.
[source]Question about Samsung Digimax S500 Digital Camera[/source]
Try replacing batteries (high Ah photographic type).
The lens motor & electronics may be draining power if Ah capacity has dropped too low. At night, it could be that your flash is trying to fire (another drain), or shutter timer / mirror staying open longer.
Sep 20, 2017 | Samsung Digimax S500 Digital Camera
I have a samsung digimax i6, ive had it now a year. anyway my problem is, when i try to turn on the camera with the 'Power' button it wont come on, only with the play button, also my shutter is open when...
It definitely sounds like you have a manufactural problem with your camera. Contact Samsung, and explain the problem to them, and see what they can do. Let me know what help they are able to give you.
Dec 19, 2008 | Samsung Digimax i6 PMP Digital Camera
Will not turn on
Sounds like your lens is stuck. Try a gentle tug and it should open all the way. Then you can power your camera down.
Nov 01, 2007 | Samsung Digimax S800 Digital Camera
Samsung Digimax A7 digital camera
Contact the Samsung Technical support for a repair opinion Then look up your local Internet for a repair firm Bear in mind the likely cost will be heavy. It may be a case of you paying a lot of money for shipping/insurance/Inspection/only to find it cannot be repaired because of lack of parts.
Jun 12, 2007 | Samsung Digimax A7 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Digimax i6 pmp SHUTTER problems!!!
Congratulations on fixing the problem! However I just wanted to let you and everyone else who reads this solution know that the part which failed on your camera is not actually the shutter. The shutter is deep inside the lens assembly right next to the image sensor. What you were dealing with was simply a protective cover for the lens. David Millier Advance Camera Repair
Feb 03, 2007 | Samsung Digimax i6 PMP Digital Camera
Open Questions:
Samsung Digimax i6 PMP Digital Camera Logo
303 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
