Question about Samsung ML 2010 Laser Printer
The paper only feeds part way and then stops. Red light comes on
The printer will appear ok so i print something. It will begin pulling the paper in and then about 1/4 of the way up the paper will stop feeding and the red light comes on and it won't do anything else. After I open it and pull the paper back out and start over, the light goes back to green and it seems fine again. The process repeats.
  • 4 more comments
  • Magsaroo Nov 19, 2008
    Ditto, exactly the same problem. Please help as people I bought printer from are not being cooperative about taking it back to look at it and I don't want to have wasted my money.
  • Louisa Gap Nov 20, 2008
    Sorry I don't have a solution. I have the same problem.!
  • pgsa Nov 21, 2008
    Same problem - the printer is about 2 years old - I'm using 28lb paper.
    The problem appears to be getting worse.
    Any other suggestions?
  • fayjarvis7 Nov 24, 2008
    I use printable checks and they work fine. When I use regular paper (20 weight) it won't pull through. We decided that the little rubber wheel that catches the paper is losing it's grip because of age and/or dust. Any ideas where to purchase a new one and how to install it?
  • Anonymous Nov 28, 2008
    Same exact problem here. Same weight paper. I wonder if a heavier/lighter paper would work better? I do not think the age is problem since my printer is practically brand new. Bought it 11 months ago but I print very infrequently.
  • ericwmast Dec 11, 2008
    I have this problem too. Totally frustrating, bceause it might work once in a while, nothing appears to be wrong or different.
Following a suggestion on another post, I tilted my printer so it is at a slight angle backwards, higher at the front. So far this has worked.....
Posted on Nov 21, 2008
I don't have a solution but I have the same problem. Any ideas anyone?!
Posted on Nov 20, 2008
  • Louisa Gap Nov 21, 2008
    Samsung say that there is either a paper clip in the machine or people are not using the correct weight paper. I tried a heavier weight paper and so far so good.
bluenorthern
SOURCE: Paper feeds unevenly and won't feed properly
For me, although the paper was folding and jamming on the right, the problem was the farthest left roller. Just push a regular index card past this roller until it doesn't stick.  Good luck and thanks so much for this site.
Posted on Dec 29, 2007
Ajkill
  • 2035 Answers
SOURCE: Paper will not feed into printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 24, 2008
SOURCE: paper feeds through crooked and comes out crunched
Hi - googled and found a good Epson site with info on this - reproduced below - the part that worked for me was allowing a small bit of room between the paper on both sides and the paper guides (counterintuitive...) rather than flush up against them.
From the Epson instructions:
You can try using the Epson cleaning sheet (has a sticky side) to pick up any excess paper residue. It's available from the Epson Store.
Try loading heavier stock paper, such as 24 lb. paper, if you haven't done so already.
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Posted on Sep 07, 2008
SOURCE: My MP470 Pixma won't feed paper, it pulls right
Based on instructions from your website I pushed a letter sized piece of thin cardboard backwards through the paper feed rollers then shook the printer while holding it upside down. A Q tip fell out, problem solved.
Posted on Jul 30, 2009
pineworks
  • 4041 Answers
SOURCE: paper feed not working properly. paper feed pulls
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 01, 2010
Printers lights is on but not printed properly ,i do test print but after 1 cm paper eject stop the printer in normal green light, and when i eject the paper after pressing feed button eject in 1 cm and...
You have something down in the unit or the roller carrier is broken - you must pull it apart or turn it upside down and shake it - after you will find something that will either fall out of it - like a paper clip or something of that nature or a bolt has come loose.
Best of it
Gary @ Fix Ya
Nov 26, 2010 | Zebra LP 2844 Thermal Printer
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Mar 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
HP Photosmart 7450 stuck cartridge
not a solution, my paper feeds past the point where printer5.gif would normally begin. Then flashing light changes from green to red and print operation stops. Printer cartridge1.gif appears to be stuck in far right area of cartridge track.
Replaced drivers as above and still have the same problem.
Mine started after I had replaced the color cartridge. Mailed the old one to HP already so can't put in old cartridge.
If I unplug printer from computer, I get same results. Does the driver software install in the printer?
Geo
Mar 28, 2008 | HP Photosmart 7450 InkJet Printer
Paper not being pulled in
If this is an older printer then try roughing up the feed wheels with abrasive paper.
Also make sure the feed/delivery trays are correctly engaged
A simple knock will put them out of true.
A repair shop - is not an option- printers are considered 'consumable' these days like so much other small electrical stuff.
Dec 24, 2007 | HP LaserJet 1018 Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Samsung ML 2010 Laser Printer Logo
235 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
