Question about Sony Alpha DSLR-A100 Digital Camera
Cf card reader sony a 100 dslr
Repaired twice , two different shops [mack &precision] even with new cf cards , I take some pics everything fine , but when I remove card and reinsert it I get error , no card ,formatting, unable to read card.first repair was for cable release got unhooked. worked good for a few months.second was for bent pins, came back with same issues. problem with card reader back for rework at mack
  • cas Nov 15, 2008
    professional cameras use cf cards all the time
    Champion:
  • 225 Answers
Buy a camera that does not use CF. Time to upgrade.
Posted on Nov 13, 2008
  • ArmstrongEle Nov 17, 2008
    Well, you do not have to worry. Compact flash makers has announced they will be releasing a new card format in 2009 for professional cameras. The card type you currently use will now slowly fade away. Read up on the new compact flash tech called CFAST if you wish to know more.
I have a Sony Ax200 DSLR-A200K and it gets stuck after I take a certain amount of pictures. It says 'unable to display' and when I try and delete it, it says 'card error'. Can you help?
You need to format the card. This is best done in the camera. Go through the menu to find camera settings (not picture setting) One of the options should be to format memory card. This process will WIPE OUT EVERYTHING on the card. If you want to save some pics, do that first.
If format errors out, it means the memory card is defective. Retry once or twice, even retry in a PC if possible, otherwise buy a new memory card.
Nov 10, 2010 | FUJIFILM FinePix AX200 Digital Camera
My cam takes the compact flash card. i just bought a new card. after i put it in the cam,the cam wanted to format it, i chose yes then the cam said it couldnt use the card. i bought another card and it did...
Probably a bend, or broken, or 'pushed in' pin in the CF slot. Its a costly Sony Service shop repair
In future get a camera without all those delicate pins! (SD)
Oct 20, 2009 | Sony Alpha DSLR-A100 Digital Camera
Canon EOS-1D won't save pix to CF card. G.
The E99 message usually ends up being a shutter box that needs to be replaced. The 1D shutter box should be good for 100,000 images or more, you can probably find the estimated lifespan on Google somewhere.
If you can"t save pics to the CF card then you might have a bent or broken pin on your CF card reader. Look down into the CF slot, does it look ok?
We are an online digital camera repair shop but we haven't done any 1D cameras before.
Thomas D,
Owner; Darntoothysam com
Oct 02, 2009 | Canon EOS-1D Mark II Digital Camera
MY MEMORY CARDS NO LONGER WORK IN MY SONY DSLR A100 CAMERA?
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.
Best regards - Michael
Jan 12, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
I can't format any memory card (CF) with my Sony Alpha 100
you have a lock on your memory card check that !!
Jan 03, 2009 | Cameras
How do i down load pic on computer
Almost any computer store (even drugstores these days!) sell inexpensive memory card readers that have a connector that you plug into a USB port on your computer. Most have slots to read several different types and sizes of cards. Just be sure that the reader you buy takes CompactFlash (CF) cards that the Nikon 5700 uses. Your computer treats the card and reader as one more disk drive.
Aug 08, 2008 | Nikon Coolpix 5700 Digital Camera
Sony DSLR A100
Try a different CF card, preferably a new one.
Jul 06, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
My CompactFlash card is no longer recognized by my computer (Sony Vaio notebook w/Windows XP home edition)
It isn't clear from your description, but are you inserting the reader into your USB port, and *then* inserting the CF into the reader? If so, try reversing this -- insert the CF into the reader, then insert the reader (with the CF) into a USB port. It is possible that your PC is only looking at the reader once (when it is inserted) and not finding a CF, then ignoring the CF once you insert it. If your camera can read and write to the CF, then it is unlikely that the CF is damaged. Since you have determined that the reader is ok, and since your PC recognises the reader, it is unlikely that it is a USB driver problem. Similarly, it is unlikely that it is a physical problem with the USB port, or the pins in the reader or the CF card.
Mar 03, 2007 | Canon PowerShot A50 Digital Camera
Can't power on with CF card
Buy or borrow a new Cf card. These cards, even when all the pins etc. are fine, often fail internally. They are not, as many people believe, a totally foolproof way to store data. If you get a similar problem with a different NEW card then you have to get the camera repaired professionally. Also to try would be reading your suspect card in a card reader on a pc or in another similar camera to see if you have similar problems - confirming if the card is the problem. However if the card seems to work fine in other appliances, it is probably the camera that is the problem, although Cf cards can be temperamental like that especially when they get a little old.
Dec 24, 2006 | Canon PowerShot A75 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
612 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
