Question about Janome Sew Precise Mechanical Sewing Machine
Stitch problems I'm making a simple quilt. The material will not feed evenly with the batting in the middle. Another problem is the reverse stitch will not stitch properly. The stitches are lumpy. My Janome machine is new. Could the factory settings be wrong. I have sewn for years on other machines. First time on this machine and I can't get stitches even. Thanks, Linda
    Sergeant:
    Champion:
  • 240 Answers
You can adjust the pressure foot(not footpedal)which puts the prsure on the foot by the needle. Also try altering the stitch length. If the stitches are skipping on silky fabric or knitted fabrics try using tissue and sewing onto that directly then tearing it off afterwards.
Posted on Jun 11, 2009
Correct tension for fmq
Not sure what you're asking. FWIW, for FMQ, stitch length should really have no affect if you drop the feed dogs. The stitch length is determined by how fast you move the fabric and how fast the machine stitches.
For tension, it is dependent on your particular machine. To make that determination, make up sample sandwiches made of the same fabric and batting as your quilt and practice FMQ and adjusting the tension until the threads meet in the middle of the sandwich. For most of my FMQ, I use a specific bobbin case that has been adjusted and used only for FMQ.
Jan 17, 2018 | Sewing Machines
I have been given janome 525s the material not feeding through the foot. Unless i pull material it wont move
Make sure the feed dogs have not been dropped, ie for darning or free motion quilting. Also, make sure the stitch length is set high enough to actually create a forward stitch.
Mar 18, 2017 | Janome Sewist 525S Mechanical Sewing...
Janome 1600P DBX
You need to drop the feed dogs, install a darning or free motion quilting foot (make sure the presser foot is lowered). Because you will not be using the machine to move the fabric, the stitch length selection is of no importance. Make sure the stitch width is set to zero. You should test FMQ on a scrap quilt sandwich of the same makeup of your project, ie quilt fabric with batting sandwiched between. The upper tension should be set so that both threads meet in the middle of the quilt sandwich. Because it is FMQ, some extra adjustment may be needed.
Once the tension is where you want it, you can practice FMQ until you can move it smoothly in conjunction with the machine speed.
Practicing on a white board with erasable markers is a handy way to learn to move smoothly. The most difficult part of free motion quilting is learning to move the fabric smoothly. Do NOT lack for practice as that is the only way to improve. Those people who make it look simple have been doing it for years!
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners Part 1 Video from Sewing with Nancy
Learn How to Free Motion Quilt Stippling
Oct 31, 2016 | Janome Sewing Machines
On a baby lock 6300, it's threaded correctly but when running, the track (feed system)under the foot won't pull the material through. What can I check? There are no repair shops anywhere in my area.
1. It most likely is the foot pressure not set properly. With thick material it needs to be less and with thin material it is opposite. Just test a piece of like fabric that is rags.
2. Make sure that you clean out any thread under the plate as good as you can.
3. Check your tensions. The top should be around four. The bobbin tension has to be even with the top tension. (like tug of war) However, when you thread the top do it with the foot up to check for snags. Snags are a serious problem and cause the material from moving. Good Luck.
Jul 24, 2016 | Baby Lock Sewing Machines
Why do stitches bunch when using walking foot on 3 layers of quilting fabric?
make sure that the thread tensions are correct for the thickness of material
remember that only the bottom foot walks and draws the material through so it may need a help and be pulled as it sews.
I find that women in sewing shops just love to talk about problems and how they can help so find a shop and discuss any problems with them
May 08, 2015 | Brother PC420-PRW Project Runway...
Viking designer 1
Hi, Free motion quilting is done with your programmed quilting stitches, Lower the feed dogs using the small white dial on the front of the machine behind the accessory tray, pick from one of the quilting stitches. they do make a free motion quilting tool ( I think they call it a hoop), but it just sets on top the material and helps you guide your material thru the machine. Hope this helps
Aug 29, 2014 | Husqvarna Sewing Machines
What the purpose or uses of drop feed lever
The drop feed lever will lower the feed dogs below the so they are no longer making contact with the material. This option is used for free hand machine quilting & free hand embroidery. This means you are in control of the stitch length and which direction you are going without actually turning the material. Your hands are what is controling the fabric movement.
Jun 04, 2014 | Juki TL-98Q
I have a Brothers 1500s. When I quilt with it the stiches skip every now an then leaving a large gap between stitches. Do I have the quilt to far up from the base of hte machine when I quilt? Should the...
Your top tension is based on the fabric thickness.. not just a number. Make a test sandwich of all the materials you are quilting with, cotton top, batting, lining, etc. Test your tension on that until you get it right.
The skipping is a symptom of a bad needle or the presser foot not having enough pressure on it. I'm not familiar with your machine so I don't know if it has the ability to add more pressure to the presser foot.
Dec 12, 2012 | Brother LS-2125 Mechanical Sewing Machine
Difficulty sewing quilt blocks
Try using a "walking foot" presser foot. It has feed dogs on the top to help all the layers go through evenly. A generic brand usually fits most all machines. :)
Jan 17, 2009 | Kenmore 15212 Mechanical Sewing Machine
Brother sewing machine
Sounds like the feed is your problem. Most likely you need a different foot. Check the bottom of the foot - it should be quite smooth to allow the dog feed to move the denser layers along smoothly. Hope this helps.
Feb 07, 2008 | Sewing Machines
Janome Sew Precise Mechanical Sewing Machine Logo
267 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
