Question about Carrier Heating & Cooling
A/c unit is very hot and the fan stop working
    Novelist:
  • 124 Answers
Start with the fan motor capacitor, check it . usually 5, 7.5 or 10 microfareds.check it with a meter on the uf scale, or label wires pull it and take to electric motor shop and they can check it. if cap is good then trace wires from motor to sources of power and see if you have 230 volts to motor . if you do then motors shot. label all wires and note exactly where the fan blade is located in relation to the grill guard. sand motor shaft smooth. oil loosen bolts on blade hub and gently remove. take old motor to motor shop and buy exact replacement motor. or have motor shop man show you where to place wires. usually black and white to power, brown and brown with white stripe to the capacitor. some motors wired up with three wires. see side of motor or directions in box or ask motor man to explain. resecure new motor exactly as removed , reinstall hub and blade. if you think blade is to rusted to get off or you mess it up just take it to the motor shop. he sells blades to! just be sure you have good clearance when you get done, cap off or tape off any unused leads. i usually use little bits if stat wire to secure wires up and out of the way of the fan blade if needed. they last longer than plasties and are not effected by the sun etc. check rotation of blade. cupped or curved side into the wind . check amps on new motor. should pull less than rated . a 2.9 may pull 2.1 etc. a new motor always deserves and usually uses a different size capacitor than an old one. they are cheap anyway and not worth skipping and having a redo. good luck........
Posted on Nov 13, 2008
I have a Dometic B3200 / 3253.332 roof a/c The problem I have is on a very hot day the a/c will run for lhours at a time then the fan will cut out however you can still hear the compressor
it is possible that the condenser is too hot to transfer the heat because the air temp is too hot
test that by spraying water into the fan ( mist) to cool the condenser and see if that stops it
or move the unit to a shady area rather than on the roof top
Feb 06, 2017 | Dometic Refrigerators
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Is the heat pump cooling itself down? It is a combination heat pump/air conditioner wall unit.
If a unit is in heating mode the outdoor unit is in cooling mode (outside always does opposite of indoor) after a while if there is a build up of ice on outdoor coil unit stops and puts hot gas through outdoor coil to clear it. The indoor fan stops to avoid and heat loss in area served buy unit once this has been done and indoor unit coil is hot again fan will start. This is the correct operation of the unit to save against bust could and reduced efficiency
Dec 31, 2015 | Heating & Cooling
Fan comes on when engine not running and running the battery down
Hello
Start car Check out fan should not work when engine cold ( ac off)
when engine gets hot enough fan should work cool down engine and stop. locate the unit controlling the fan and see if there may be a short of unit or wire to unit
Feb 17, 2015 | Cars & Trucks
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
Both radiator fans have stopped working. Not the fuse.
have you tried to hot wire them to see if they work? If they do it's probably the sendor unit on the engine or radiator not giving the signal
Jul 21, 2010 | 1996 Oldsmobile Eighty Eight
Rick55 my outside unit goodman cjk484ab stopped working fan not turning motor very hot power went out for asecond then the unit stopped working i think the fan motor went out
check the capacitor if motor is real hot it might be burnt out winding can you get it to turn buy pushing the blades if so good chance it motor.
Jun 24, 2009 | Heating & Cooling
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
External fan stops operating in hot temperatures
Replace the motor on the outside fan, It should run all the time.
Jan 07, 2009 | Heating & Cooling
Surround sound
Yes it will, the fan stops working and the amp gets hot and the unit will shutdown as a precautionary step
Aug 05, 2008 | Philips HTS-6500/37 System
Heating & Cooling Logo
64 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
