Question about Epson Stylus CX3200 All-In-One InkJet Printer
Epson dx7450 scanner connection issue
When i try to scan the scanner gives me an error message that says that my cartridge unit may be locked dependin on your scanner model. I have tried everything i can think of, the scanner is properly connected to the computer and everything else works please help!
  • 1 more comment
  • jonybravo78 Feb 19, 2009
    i have the same problem, anyone???
  • Anonymous Apr 22, 2009
  • cobeyug May 07, 2009
    When I start scanning a document, there is an error message appearing that says:
    Cannot properly communicate with the scanner. The carriage unit may be locked depending on your scanning model. Make sure the scanner is properly connected and set up to scan. Then, turn the scanner off and back on again.
jackboy
  • 2985 Answers
SOURCE: scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Posted on Aug 02, 2007
Rain041304
  • 63 Answers
SOURCE: Scanner not recognized by computer
Try to check control panel>device manager>check if there is an imaging device on the list. If none, it means that the computer is not detecting your printer. Try to plug it in to other port or try to use another usb cable. If still won't work, you need to uninstall and reinstall the drivers for the scanner
Posted on Feb 07, 2008
SOURCE: Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Posted on Mar 06, 2008
  • 125 Answers
SOURCE: Epson DX6000 scanner problem
If it's a new printer, try changing the USB printer cable. Sometimes one of the wires just gives out and doesn't communicate properly between the printer and your PC. Hope this helps.
Posted on Aug 01, 2008
gwbm
  • 353 Answers
SOURCE: EPSON PRINTERS how to replace inks in epson DX 7450
You must surely have sorted this one out by now Doris! However, if you haven't, how to change print cartridges on a DX7450 is very clearly explained in the user handbook (on the CD that came with your printer). Insert the CD and select "Custom Install" then "Users Guide". Once its installed, double click the new Epson Icon on your screen and selct "Printing" then "Replacing Ink Cartridges". If you don't have a CD, download the User's Guide from the Epson website at http://www.epson.com - just choose your locale, then select Get Drivers and Support - Printers.
Posted on Nov 28, 2008
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Nov 23, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
MY SCANNER FOR PRINTER EPSON DX7450 HAS BEEN BY MISTAKE DELETED, HOW CAN I INSTALL SCANNER WITHOUT THE DISK
on this page
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX7450/Drivers-Support
you can download driver.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 27, 2011 | Epson Stylus CX3200 All-In-One InkJet...
Replacement black cartridge in DX7450 will not work
try to clean the cartrige with tissue paper and try to align it
Mar 27, 2010 | Office Equipment & Supplies
Epson DX7450 won't recognise compatible cartridges
This is a common problem and is caused by faulty or missing chips onthe compatible cartridges. You will need to get them replaced otherwise the printer will not operate. Contact the vendor where you bought them from and ask for repalcements or a refund.
Sep 30, 2009 | Office Equipment & Supplies
Epson cs5500 scanner software wont work
try downloading the latest drivers from epsons website. if coping is working and printing is working, it sounds like a software problem. Its possible there is a bug in the scanner part of the drivers.
May 07, 2009 | Office Equipment & Supplies
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
384 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
