Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
My router reads waiting for dsl
My router has a dsl connection can i still use as just a router?
  • Jannette Amandy May 11, 2010
    What is the exact model number of the router you have?
    Scholar:
  • 62 Answers
Yes, youi can use as just a router, I use to do it myself, I had a netopia behind a linksys
but the netopia is actually a modem/router in 1.
you can also use as just a modem if you put it in bridge mode.
spin
Posted on Jun 22, 2009
My next book can't connect to WiFi because Mac and IP address is unavailable. What do I do
1) Turn off your netbook
2) Power off the router by unplugging it
3) Power off your cable or DSL modem (if different from your router) by unplugging it
4) Power on your cable or DSL modem and wait for the blinking lights to "stabilize" a bit
5) Power on your router (if different from your cable or DSL modem) by plugging it in and wait for the lights to stabilize a bit
6) Turn on your netbook
7) Test connectivity
Feb 01, 2015 | Computers & Internet
CNet wireless router Model CWR-854V. is causing my Ethernet lite on my DSL modem to blink causing me not to be able to get on internet. Changed all cables no help disconnected Router and modem works...
Use an Ethernet cable to connect your computer directly to the DSL modem, bypassing the router, turn the modem off, turn the modem on, wait 60 seconds, and restart your computer.
Does the Ethernet lamp still blink when Windows is booting, and when you are using the Internet?
Turn the DSL modem off.
Turn the router off.
Turn the computer off.
Disconnect the Ethernet cable from the modem, and connect it from the computer to the router.
Turn the router on, and wait 60 seconds, then turn your computer on.
After Windows is running, click Start.
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: default gateway........ 192.168.123.456
If the string starts with '192.168', then your computer *IS* "talking" to the router.
Now, use an Ethernet cable to connect the WAN port on the router to the DSL modem.
Turn the modem on.
Turn the router on.
Wait 60 seconds.
Restart your computer, and you should be able to web-surf.
Jul 19, 2011 | Cnet CWR-854 Router
All lights of the modem are on but there is no internet connection although I reset the modem, turned off everything and unplugged and waited for 6 minutes. Besides, I went to the 192......., put the dsl...
1. Call DSL provider verify service is active. They should be able to ping their DSL modem.
2. If good service, plug your pc directly into dsl modem. If youre able to connect, then the router is bad. Youll need a new one.
3. If I read this wrong, and its the dsl modem that is not connecting, AND the service says its working, then it maybe the dsl network port has failed. In which case report it to your service provider and they should replace the unit for you.
4. You can try to unplug and replug the network cables, all of them. Or try different ones. Its just possible you are getting a poor connection at the wire terminator.
May 24, 2011 | Computers & Internet
Have dsl connection, works fine. when linksys wrt54g router is correctly installed, no internet connection! ran diagnostic, all is fine, but no internet connection found-can't seem to upload new firmware...
Turn the Linksys router off.
Turn your computer off.
Turn the DSL modem on.
Wait for its lamps to settle-down to a consistent pattern.
Turn the Linksys router on.
Turn your computer on.
Wait for it to settle-down.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
You should get output somewhat like: Default Gateway .... 192.168.123.456
if you have a connection between your router and your computer.
If you have that connection, you should be able to upload new firmware from your computer to the router.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
My router cant connect to the internet.
Did you try a factory reset?
With the router powered on and running, se a toothpick or something like that to hold the reset button down for 20 seconds. Release the reset button and wait for the router to reboot. This usually takes a minute or two.
You may need to reboot your computer, although it's generally simpler to unplug the ethernet cable from the router (after the factory reset), wait 30 seconds, then plug the cable back in.
This is also known as 'renew dhcp lease'.
If that doesn't work, try powering down your cable modem/dsl adapter, power down the router, then power up the cable modem/dsl, wait for it to connect, then power up the router.
Some cable modems and dsl boxes 'lock on' to the first ethernet adapter they see, this will make the cable/dsl box reset the lock.
Aug 29, 2010 | D-Link AirPlus DI-524 Wireless Router
No internet
Power down your modem and router by unplugging them. Wait 30 seconds. Plug your modem back in and let it cycle through. Wait until it's fully connected. Plug the router in and let it cycle through. That should fix your problem.
Oct 29, 2009 | Belkin Wireless Cable/DSL Gateway Router
Remote manage a DSL 504T router
If you have a dynamic IP on your wan port you shall register a domain name and register it with dynamic DNS, provide your dynamic dns name in your DSL router so that you shall connect to your DSL router by calling the registered dynamic dns name from any where (you should have internet connection).
1. Register a name in dyndns.com
2. update this on your dsl router
Wait for some time,
3. access the registered name from anywhere using a browser
Jun 09, 2009 | D-Link DSL-504T/EU Router
Lose DSL connection a lot!
Unplug you dsl and your router. Wait 20 seconds. Plug your modem back in. Wait until the DSL light turns green. Then turn your router on.
Jul 16, 2008 | 2wire 2700HG-B Router (2700HGB)
Linksys router
unplug your DSL modem. Wait 30 seconds and plug it back in.
Make sure the router is connected to a DSL modem. Lately I have seen DSL modems connected to offices that are really routers. If thats the case it may not be talking because the DSL is address the gateway with the same address as the router.
The best way to test this is to see what happens when you disconnect your linksys router and type in http://192.168.0.1
in internet explorer.
If the DSL modem screen appears, it's configured as a router.
Then you will have to take the linksys router and turn it into a switch with a wireless access point. I
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
Belkin router
I just worked on one of these today. Try this and see if it helps.
1. Unplug your cable or DSL modem and your wireless router
2. Plug back in the cable or DSL modem and wait for the internet to successfully connect (watch the lights).
3. Plug the wireless router back in again and wait for it to connect (again, watching the lights)
If this doesn't work, make sure you have the equipment plugged-in in the right order.
cable or dsl signal goes to modem ==> modem plugs into wireless router ===> computer plugs into wireless router.
Feb 02, 2008 | Belkin (F5D7230-4) Router (587009)
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
146 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
