Question about Jensen TS2750J TV
Blurry Screen Couple of days ago the screen was all of a sudden very blurry. It happens when watching T.V. or watching games. Everything I've tried doesn't work (unplugging, messing with the settings). When I change the channel the screen has a red tint to it instead of just being the usual black screen when changing channels. The TV is less than a year old and nothing has happened to the TV. Thanks
  • 790 Answers
Ok your problem is the RGB section maybe crack soldered at the RGB try to resoldered it! you seen that at the back of the picture tube they have small board attach at the neck... resoldred all small part, and transistor drivers!!!
Posted on Sep 06, 2007
KP-51WS500 it started a couple months ago the
Hi, that is look like ,,you have defective convergence module if it is a dlp it is probly the light bulb,
hope that will help you to find a good tech
to fix it.
have a nice day
May 05, 2010 | Sony KP-51WS500 51" Rear Projection...
Screen on all games is blurry. Just started
make sure its not your tv.there might be something wrong with your xbox or you did something in the options menu that messed it up
Jan 20, 2010 | Microsoft Xbox 360 Console
Icons are blurry
Did it happen all of a sudden? In other words, was it OK before?
Try going to screen preferences, settings, and look at the resolution slider - is it set to the native resolution of your monitor (1280x1024)? If not, correct and accept changes.
If the resolution is set OK, then multiple other things might have happened, but not knowing a bit more about the situation it's hard to advise anything...
Nov 08, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
Blurry Screen on Panasonic CT-32HL44
I solved my problem. Apparently the RCA cables where missing with the image. So I bought some Component cables and that fixed my problem.
Dec 30, 2008 | Panasonic CT-32HL44 32" TV
Blurry
Right off hand I'd check the focus . By turning the camera lens left or right may cure the problem. Sound likely to be the focus. Hope this is of some help. Bud
Feb 22, 2008 | Philips SPC700NC Webcam
Bottom touch screen blurry
it happens if there is moist or dust or sand inside the ds so breath INWARDS through the L or R buttons but dont pull too hard but **** as much as you can until it becomes alright plus keep doing it ... it took me 10 mins to get it right
Jan 05, 2008 | Nintendo DS Console
Screen goes from blurry to clear to blurry
The first thing to check is for loose conections,the problem is related to the high voltage but it can start in the main board with one component loose,when the high voltage is developed it goes to what is call the distributor block,a lot of sets have the focus and screen controls coming out of this block for each picture tube,this block might be bad but before we go to him we need to check everything is solid in the main board.If you are familiar with electronics you can remove the back cover and tap the chassis with a wooden or rubber handle to see if the set reacts,if it does you need to be atentive what area makes it react and flip the board to do some resoldering,If you are not too familiar with tv service you need the assistance from a servicer.Let Us know how it goes or if you need more information.
Oct 27, 2006 | Zenith H32G48S TV
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
151 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
