Kenmore 24032\24036 Top Load Washer Logo
Posted on Nov 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine will not spin
After the wash cycle is done, it will not go into spin cycle, thus not draining
  • suriyakamal Nov 12, 2008
    machine does not spin
  • Anonymous Nov 16, 2008
    washing machine will not spin and drain water out. my husband said it has no belt on it . kenmore large top load washier
Anonymous
Level 2:
New Friend:
  • Expert 160 Answers
  • Posted on Nov 12, 2008
Anonymous
Expert
Level 2:
New Friend:
Answers
160
Questions
Helped
127184
Points
461
Sounds like you have a bad door switch
2answers
A128QW BUSH washing machine.When set to number 7 for quick wash when it gets to spin cycle light flashes and nothing happens? do you know what can be done?
If this only happens on quick wash, it could be that this cycle does not spin. I have come across a few washers that do not spin on short or quick wash cycles. If it spins on all other cycles, I would say the machine is OK.
1helpful
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
When our washer is done with the wash cycle, it doesn't drain the water out and so when it's on the spin cycle, the knob just ticks through it. What could be the problem for the water not draining out, a...
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
I have a kenmore 90series the problem is that when it's done washing it want drain out all the water after two spin cycles
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
HI mate , if your model is an LG 8013F . I had the same problem . evrything is control by the CPU and it cannot be repaired .
What i had done is to replaced the Control board completly and it works perfectly .
I have one unit extra if u are interested let me knw , i can sell it for $60 + PP
THanks
Hans
Alexander
vince
