Question about Brother GX-6750 Typewriter
Return key when I press return it will go back all the way to left position but will not advance to next line Gx-6750 brother
    Scholar:
  • 183 Answers
The "index" motor has gone bad or the gears have broken, will need a visit to the repair shop, or get a new one
Posted on Nov 17, 2008
How to change the font on the GX-6750 brother typewriter
You have to buy a new printwheel or daisy wheel with smaller fonts.
Jul 07, 2014 | Brother GX-6750 Typewriter
I installed a new cartridge ib my Brother GX 6750 and it is not printing..The keys are working fine however it is not hitting the tape to print.
Hi!
Neat little typewriter.
Think back, and reverse the steps.
Before you removed the finished ribbon, you had to pull on a little lever that is next to the printhead, right?
Now that you inserted the new ribbon, you must push that same lever towards the platen, away from you, in order to lock it back in the normal printing position.
Please feel free to contact me if you wish.
Feb 13, 2011 | Brother GX-6750 Typewriter
How to you set a Brother GX-6750 typewriter to double strike each character?
It's called BOLD on that machine.
Press and hold down ALT key and Press RELOC/BS ½ (if you look it says BOLD above the key) You will hear 2 beeps
To cancel bold type [ALT] + [BOLD] again
Nov 30, 2010 | Brother GX-6750 Typewriter
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
In need of a brother GX-6750 typewriter owners manuel please help
First press the Code key and Q simultaneously. That will reset the wheel position. If it clicks or otherwise fails to type properly, pull out the wheel and inspect it. One or more of the types may be bent. In that case, the wheel needs to be replaced. Good luck finding the part.
Feb 03, 2009 | Brother GX-6750 Typewriter
Ink cartridge pops up when the return key is hit...
go to http://www.brother-usa.com and you will find a printable user's manual for all models
Dec 04, 2008 | Brother GX-6750 Typewriter
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Jul 16, 2008 | Brother GX-6750 Typewriter
Brother gx-6750 typewriter
Make sure the knob for the platen (roller) is tight. Hold the roller and turn the knob to tighten.
Jun 24, 2007 | Brother GX-6750 Typewriter
Help with Typewriter
hold down the code key and press the margin release, to set margin, just hold code release margin, space over to where you want it and then press Margin set, left or right.
Jun 05, 2007 | Brother GX-6750 Typewriter
Margin Release for Brother GX-6750 Typewriter
Typewriters have alimit to how far to the right or left that you can set margins. Once you use the alt & 6 key to bypass the current margin setting then move to the new setting then hold the alt key and touch the 7 key to keep it in the new position.
Mar 09, 2007 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
76 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
