SOURCE: lt180 won't run without choke
Hi, disassemble and clean all jets in the carby, also check the valve clearances are correct because if they too tight the engine will not draw fuel in. Hope this helps, regards Phil.
Testimonial: "thanks I'll give it a try....new carb -replaced last year, but hearing the ethonol is destroying mowers"
if anti back fire selonoid is disconnected how
are you getting fuel? if so ck selonoid again make sure it is open. should run
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
SOURCE: my john deere lt133 riding
Hi, what are you calling proper voltage? If its a gap tester it should jump at least 8mm. If its a peak voltage tester it should be at least 12,000 volts. If not the ignition module is faulty, which is very common on kohler engines. Hope this helps, regards Phil.
SOURCE: I have a craftsman lt 1000 riding lawn mower and
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
