Question about Bose Companion 3 Computer Speakers
The right speaker dosnt work in companion 3
When i press pay the left speaker works fine but when the right dosnt, i mean it works but with very low volume.
  • 2 more comments
  • rhsieh Nov 13, 2008
    It's not a problem with the satellites, it seems to be an issue with the right out on the subwoofer, going to write to them now...
  • garbopash Jan 02, 2009
    i have a similar problem: i just bought them and the right speaker only works when the control pod is turned up fully.
  • Anonymous Jan 08, 2009
    i have same problem, nothing wrong with speakers, seems like just subwoofer has problemĀ
  • Anonymous Mar 20, 2009
    I have this EXACT same problem. I purchased on 8/30/2008 at a Best Buy in Houston. The speakers are still under 1 year warranty so I am going to see what they will do about this.
SOURCE: bose companion speaker stopped working!?
What happened to you is probably mere coincidence with your cousin's use of the headphones and this is throwing you off. I own the Bose Companions also and they stopped working as well. However, I traced the problem to the "wall wart" power supply. Not sure why but Bose is now using an interchangable plug on them. If you look at the power supply you will see a "PUSH" button. If you depress it the plug can slide out. When it is slid back in and locked in place the connection between the plug plate and the power supply is not a good one. Try fiddling with it. But even if the connection is not the culprit, something in the power supply is. I swapped another power supply with the same connector and spec's ( amps must be the same ) from another item and the speakers worked perfectly.
Posted on Dec 14, 2008
SOURCE: Bose Companion 3 Series II speakers volume problem with Adapter
use 220 volts , 50 watts
Posted on Aug 06, 2009
fixyathing
  • 341 Answers
SOURCE: Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Posted on Aug 12, 2009
freetek
  • 5568 Answers
SOURCE: I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Posted on Dec 14, 2009
SOURCE: My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Posted on Aug 03, 2010
My Bose companion 20 right speaker will not work on my I pad
Plug a pair of earphones into the iPad to see if the problem is the speakers or the iPad. Once you have the piece that's not working correctly figured out, it's time to take it to the repair shop.
Jun 12, 2015 | Bose Companion 20 multimedia speaker...
My companion 3 series II Bose speaker system is not turning on the control board dosnt light up and it dosnt seem to work idk if its a fuse or what I also need to know how to open the box because only
This is most likely the power supply inside the unit. If there are no screws present then it is likely sealed and hard to open without damage.
Dec 07, 2012 | Computers & Internet
I have a Bose sound system companion series 3 ii and the lights just yellow and no sounds coming out and it turned red and no sound was still coming out.It was working fine about half a an hour ago
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
Dec 25, 2010 | Bose Companion 3 Computer Speakers
Jul 29, 2010 | Bose Companion 3 Computer Speakers
I've had the series 1 companion 3 for almost 4
Hi, This could just be a sign that your Speaker system is wearing out , and done its due...Also have you had any Power Failures or surge's Lately , if so then it could of damaged the Speakers aswell..
Hope you come right bud
Happy new year
Dec 28, 2009 | Bose Companion 3 Computer Speakers
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
I use low wattage of transformer to my companion 5bose speaker now there is no sound what should i do.
i suggest that you will stop using that low wattage transformer. Using that transformer might destroy your speaker. You should provide the right wattage which the speaker is requiring. Just look at the back of the speaker and you will the required wattage.
Andrezarion
Mar 22, 2009 | Bose Companion 5 Multimedia Speaker System...
Bose Companion 3 Computer Speakers Logo
309 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
