Question about Hotpoint VBXR1090D Top Load Washer
Hotpoint older model washer spins wont drain
It spins no problem but it wont drain and it just keeps going.  I usually put the dial on the normal wash but it went through it and on to the delicates cycle for some reason?  But I looked in and tons of soap and not draining at all??  Not sure what to do.
  • 1 more comment
  • j_townshend Nov 13, 2008
    perfect!  You were right.  It was a sock in there!
    Thanks!
  • adama1979 Apr 17, 2009
    wont drain
  • cmanjo May 07, 2009
    I have the same problem and saw your response, but how do I get the water out so I can do all that technical stuff you mentioned?
    Novelist:
  • 166 Answers
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Posted on Nov 12, 2008
Hi. i have had funny noises during last couple of washes. now washer wont drain programs are responding fine but washer keeps filling up and not draining.water backed up and came out of the drawer hotpoint...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
VBSR3100, fills and agitates but nothing else works
CHECK OUT THE DRAIN MOTOR PUMP , Its where the drain hose is connected to , youll see like a small fan , it could be clogged and needs to be removed for cleaning, hope it helps , AJ
Jul 24, 2010 | Hotpoint VBSR3100D Top Load Washer
Will not go onto final spin on its own
check drain hose lid switch ....plugged pump or drain hose last timer
Aug 14, 2009 | Hotpoint WMA48 Front Load Washer
Not draining and washer arm not spinning
Have you cleaned the drain filter? The symptoms you describe indicate that the filter are totally clogged.
Cleaning filters should be done every other week to maintain good function in dishwashers, it is not uncommon people forget that.
You access the filter by removing the perforated stainless steel plate at the floor of the washer tub, usually there is a round plastic knob in the middle that you turn counter-clockwise then lift it up. Underneath this plate you will find the main filter, take it out and clean with a soft brush under running water.
May 24, 2009 | Hotpoint 24 in. HDA2130Z Built-in...
Wont rince
Hi
you need to remove back panel at bottom from there you will see a black hose going from the tub to the pump . remove this and check for blockages and the same for the pump . remove debris from them and try machine again hopefully should be back to normal
regards dan
Mar 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dial keeps turning on machine
machine wont operate when dial is at rinse
Jul 17, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint WD420 Washer/Dryer - Not completing cycle
I WOULD FIRST CHECK THE COLD WATER VALVES ONE COULD BE INTERMITTEN
Jun 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD440
Bad door latch or Control board is bad
Apr 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint VBXR1090D Top Load Washer Logo
122 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
