Question about Briel Domus Due Espresso Machine & Coffee Maker
Spares for Briel Coffee Machine
Where can I obtain an on/off switch for my Briel Versatile Due model ES38
  • 37 Answers
You can obtain any part at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Nov 20, 2008
Need new reservoir
You can contact Briel direct they will supply spares but only from Portugal (I am in UK no one held spares) Email customer service Remember post costs could be high so consider replacing the Briel locally as it is obsolete and although a good entry level grinder, far better ones can be obtained and after all grind consistency is everything. If it is just the return spring see my FixYa. Address below Anabela Maia de SousaAfter Sales ServicesBriel - Industria de Electrodomesticos, S.A.Rua Sidonio Pais, 390 - Lugar do Rio4475-498 Nogueira da Maia - Portugalanabela@briel.ptwww.briel.ptTel: +351 22 961 9430Fax: +351 22 961 9435
Jul 27, 2009 | Briel CG5B Electric Burr Grinder
Cleaning oils from briel domus
Yes, every pump driven machine has an over pressure discharge.
Jun 18, 2009 | Briel Domus Due Espresso Machine & Coffee...
Manual Briel ES161atb
Don't know about replacement parts but instruction manual can be downloaded from the website in PDF file.
Jun 13, 2009 | Briel Domus Due Espresso Machine & Coffee...
Briel Versatile Due Coffee Machine
You can get it at the Briel service/distribution center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Sep 05, 2008 | Briel Domus Due Espresso Machine & Coffee...
Spares
Try these people
I got a new basket from them for about $6
Electra-Craft, Inc 41 Woodbine Street Bergenfield, NJ 07621 201 439 1700
Aug 27, 2008 | Briel Domus Due Espresso Machine & Coffee...
Replacing o ring for steam wand
Not dim, though you may need to find a long screwdriver.
I've already disassembled my machine, which is the ES37S model. Yes, you remove the rubber stopper. Then you take a long and skinny screwdriver and remove the phillips-head screw at the bottom of that hole. With that screw removed, the entire plastic top of the machine comes off.
I still need to find the milk-steamer knob, which is broken on mine, so I'm in search of a parts distributor. If you have any idea where I can find Briel parts in the US, I would appreciate any contact info you may have. Thank you. ;)
Mar 08, 2008 | Briel Versatile 112924 Espresso Machine
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Espresso Machine
Possibly, if it is leaking from the bottom only, and if you have a Domus Due model, you might just need a new water reservoir as the water reservoirs are a different system than all of the other briel machines and a new reservoir will usually fix the problem of leaking on the bottom in the Domus Due machines. Something with the seal on the reservoir.
You can order just a water reservoir by contacting the service center at:
Electra-Craft
41 Woodbine St
ph 201-439-1700
If your machine is leaking over the filter handle, brew head etc, that could be the coffee oils have built up in the Brew Head Screen and/or filter basket itself. For that, remove the Brew Head Screen and soak along with the Filter Basket in a coffee oil remover (not descaler) you can get the Cafiza powder at www.urnex.com or any other brand and then use a brush to clean it after soaking. If you have the Briel filter basket with a screw in the middle, please remove the screw and clean in there as it tends to get clogged. Then just be sure not to screw it too tight again as this can cause leaking.
I hope the info was helpful.
Apr 16, 2007 | Briel Domus Due Espresso Machine & Coffee...
Briel Domus Due Espresso Machine & Coffee Maker Logo
467 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Henry  Thomas
Henry Thomas
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
