Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will not spin but when i lift the tub it will for a little
This happens during my rinse cycle
  • 370 Answers
Check your lid switch to make sure it woking (clicking) properly.
Posted on Nov 18, 2008
Maytag won't spin until you lift the lid
There is a bad spot in the timer when this is happening!!! It may work sometimes but when It gets to that spot, it won't, until you lift the lid and close it back down!!! Replace the timer!!!
Jan 20, 2014 | Maytag Washing Machines
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
My maytag washer shake a end of rinse cycle.
After the rinse cycle, the washer rapidly spins the tub to get as much water out of the clothes as it can. It works basically the same way as a salad spinner. If the weight of the clothes in the washer is not balanced, the washer will shake and maybe even jump around during the spin cycle. This is pretty normal. If all of your jeans end up on one side, and your t-shirts on the other, the jeans will hold more water, their side of the tub will be heavier, and the washer will shake a lot during the spin cycle.
If the washer is shaking too much, open it after the rinse cycle (wait for the tub to stop before reaching in) and spread the clothes out evenly in the tub. Try to balance the weight. Then close the lid/door and let it continue spinning.
Mar 05, 2011 | Maytag Washing Machines
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal De
