Question about Kenwood KAC-9152D Car Audio Amplifier
Safety overheat fuse?
I recently purchased a Kenwood Kac-9152D Amplifier, which is powering one PowerAkoustik FUBR 12" Subwoofer. i also wired in a 2 farad capacitor. Sometimes after i have my sub booming for a while, all the sudden the amp kicks out. usually if i wait 5 minutes or so it will come back on. Any suggestions as to solving my problem Thanks, JIM
  • 21 Answers
Your problem is that the transistors on the circuit board are shorting out on the back panel of the case. is the amp connected to the sub box? its caused by the vibrations through the box and amp. take off the back cover and look for some scorch marks, if there is any, find the leads on the circuit board that are causing it and bend them down a bit. i had the same problem with my amp, and so have many other people. this fixed my amp, and it has worked fine for many years after using this solution. if anyone has this problem and needs help with fixing it, email me at thadoggma420@hotmail.com
Posted on Dec 24, 2008
  • 631 Answers
How hot is the amp when it shuts down?
Posted on Oct 26, 2007
SOURCE:
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
I have a 1976 kenwood am fm stero receiver, the stero works great but just recently the face and power single lights went out, is their a fuse inside. I open the cover and did not see one.
A stereo or amp, either one should have a fuse, fuses for radios would be in the wiring harness behind the radio deck. An amp fuse should be obvious were they insert in the fuse blocks by the amps main power cable connector. If you see that all fuses are fine then check your ground wires if not then your radio is bad.
Jun 19, 2010 | Kenwood KAC-9152D Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Blown fuses
I agree with the last answer- your amp has built in fuses that should be rated at 30 amperes each which should be sufficient as the amp only pulls 60 amperes at full power-however you may want to upgrade your power /ground wires to a good 4 gauge set if you dont already have it set up like that-throw an 80-100 amp fuse up front by the battery in case your running another amp for mids and highs just to cover the current draw of the amps combined. If the amp is still blowing fuses after that check to make sure that your subs are wired to no lower than a 2 ohm load as the amp is only stable to 2 ohms.
May 11, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Power amp wont power up
Check the fuses-should be a pair of 30 amps on the side. use a paper clip and jump power from the power+ to the remote+ and see if that lights it up-if it does than your remote lead isnt giving it juice-
Apr 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
I have a kenwood kac-9152d amp i fried it opened it and the inner ground wire was fried in half now it just blows my fuses????
Dang! That's a class D anp! How did you fry it? If you "replaced" the internal ground wire and now it just blows fuses, I would say that the amp is direct shorted at the power supply if the fusesblow instantly when you put the fuses in.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 26, 2008 | Kenwood KAC-9152D Car Audio Amplifier
When i hook up the remote wire it makes my power wire go to 4 volts
If the battery is strong enough to start the engine, you probably have a bad connection or a defective fuse in the power wiring. If you solve the voltage problem and the amp blows fuses, it likely has shorted output transistors.
Oct 12, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac 9152D
Usually, protection mode is caused by one of these conditions:
  • Shorted speaker outputs.
  • Speaker output shorted to ground.
  • There is an internal issue, causing DC voltage to be present on the speaker outputs.
  • Amp overheats.
  • Ground connection is insufficient for amp or HU.
I'm not sure of the history or symptoms of your amp, but those are the reasons why the amp could go into protection mode.
Mar 13, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Will it work together
put a the amp the max charge permitted, and y you have a preamp you can makeit work.
Feb 10, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
105 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
