I have a Mannual (Non-automatic Transmission) Mazda Protege 1993 Model. I am not able to find a place to check and fill Transmission oil.
Can somebody send me diagram and help me locate the places of checking and refilling the transmission oil.
Don't listen to the other guy, I own a 1990 1.8L mazda protege with a manual transmission. Yes it will make it easier to hoist it up. I am not going into extreme detail so as long as you know a little about cars this will be a great help.
on the transmission locate the drain plug, it will be on the bottom of the transmission. don't loosen it yet you want to make sure you can fill the transmission before you drain it. there is no fill plug, you have to fill the transmission through the hole the speedometre cable is attached to the transmission. the speedometre cable is straight up and down/vertical, it should be above the passenger side cv shaft coming out of the transmission.
remove the small bolt holding it in place and then pull it straight up and out of the transmission. now drain the transmission. put the drain plug back in and start filling, make sure not to overfill you are not supposed to fill it right full.
Make sure to check the fluid level as you fill, the transmission is at the right level when the gear oil is just at the top of the speedometre gear that is on the end of the cable that is inserted into the transmission.
I believe these transmissions take 75w 90.
Hope this helped you, and maybe future people who view this looking for help.
You will have to lift it up and look around the the bottom of the tranny there should be a plug that is in the side of the case in the middle of nowhere it wont be holding anything on but be careful if there is two take the one loose thats above the other one or you will get a shower in gear oil
Having trouble locating a transmission for my 1993 Mazda is there another that is interchangeable with my car
