Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
What size batteries needed for minn kota 24 volt 74lb thrust
Heavy useage, all day, once a week. Planning on using convenional deep cycle wet batteries . thanks for the help
  • 21 Answers
I use Red Hot Mama batteries. These have held up for longer than any other brands that I have used. These are deep cycle marine wet ones.
Posted on Dec 01, 2008
What's the thrust of minn kota mag 28
12 volt its 28lbs thrust
Mar 08, 2013 | Boating
Bought a minn kota 765mxt at a yard sale and need to know is it 12 volt or more
36 lbs is 12 volt any deep cycle battery will work
Feb 03, 2013 | Boating
Will a 12 volt lawn and garden battery run my 24 lb thrust minn kotta
Yes but not for long. You need to buy a deep cycle battery. Regards Phil.
Nov 18, 2012 | Minn Kota Endura 30 Freshwater Transom...
How should a 12 volt deep cycle battery last when trolling on #1 with a 30 lb thrust
It depends on the Amp/Hour rating of the battery and the amount of current your motor draws on setting 1.
Apr 17, 2012 | Minn Kota Endura 30 Freshwater Transom...
Have a Minn Kota Riptide 70lb thrust 24 volt. While lifting the motor the cables were cut. We spliced them with a heavy duty connector and it worked fine for several weeks. Now the motor will not run on...
Does the splice get hot when you are running the motor? If yes, then the splice could certainly be the problem. I would have replaced the wire completely. However, the problem more than likely is the controller.
Oct 28, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I have a 24v pd2 70ib thrust trolling motor. What size batteries do I need
Hello there:
the 24v tells you that you need 24 volts ok so what you will need to do is to get 2 12 volt batteries and put them in series than run this to the motor this is usually done with a disconnect switch in the line with your start switch ok? you can also contact the manufacture of the motor for further details
Hope this is very helpful
Best regards Michael
Feb 01, 2010 | Minn Kota 55 AutoPilot Universal Sonar...
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Proper batterie hook up on minn kota 70 thursh
Raventrans click this link to take you to a website which will you can click on schematics. I suggest adding a 50 amp fuse for your 70 lb thrust unit. scroll to the end of the schematic to find the battery hookup for a 24 volt hookup.
http://www.mikesreelrepair.com/./index.php
Oct 15, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
592 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
