Rank: Guru
Rating: 89%, 5014 votes
The first thing I would check is the antenna or cable connection into the set.
When an analog TV signal is weak, the first thing to go is the color, then the picture, then the sound.
If you have another TV, connect it to the very same cable or antenna connection and see if it fails the same way, too.
Make sure you just disconnect the cable end right where it goes into the failing TV and connect it to the other TV - don't disconnect the antenna cable from the wall for this check.
If the second set does not fail, gently pull on the antenna wire - not too hard, you just want to put a little tension on it to see if it makes the color cut out.
Reconnect the first one and try again. If it's fine now, the connection was loose. If not, it has a tuner problem that must be repaired.
Also, when you look at the end of a TV connector, the center wire should stick out just a little bit, like in the attached photo.
If it doesn't stick out as bit, it won't make good contact, and will result in a weak signal.
I appreciate your rating if you find this helpful.
