Question about Hardware & Accessories
Can not open the wooden window blindes.
I have classic white vertical wooden blinds in the window. Unfortunately something happend with them - I can only pull them completely up. The problem is with opening blinds, so the sun light can come inside the room. In the left upper corner is a stick which is for opening or closing blinds - you can turn this stick left or right. Now it is blocked and I can not turn with the stick to open blinds (now I have then closed). Please help me to fix my blinds.
    New Friend:
If you will take the blind down and look into the top of the headrail, you will probably find that one of the metal keepers that are attached to the end of the ladder (the strings that the slats rest on) have come out slightly from the ladder drum (the round drum shaped part that the ladder attaches to in the headrail) and is hitting the inner edge of the headrail keeping it from being allowed to turn. Just put it back in - the same way the others are done and that should fix it.
Other than that one of your ladder strings may have slipped off the ladder drum and could be causing the problem; although when that happens you will typically see that your slats are not hanging level on the ladder string where the problem is.
Other than that it could be that your tilt mechanism is just bad.
Most quality blind manufacturers no longer use the tilt mechanism with the wand as they do not hold up on wood and faux wood blinds. They now use a cord tilt which is about fool proof and will hold up. 35 years experience installing blinds of all types.
Posted on Jan 28, 2015
Try to see if the rope that controls the up and down motion for the blind is not binding against the stick knob that it is attached to in order to see this you have to take the blind down and look at it from the top
Posted on Jan 03, 2009
Where do I go on your website to find out the types of blinds you have and wether they can be made to order. Your website is not informative
You say blinds? You mean roller blinds or vertical blinds? I have used 'Capricorn Blinds' in the past. Not sure whether they are still going. They're a little expensive, but make a decent product to the size you request.
If you enter on the search on your computer. 'blinds' ? Roller blinds, vertical blinds you should have a number of companies show.
If your going to do this over the internet, you are going to have to measure up the blinds yourself and they will then make them to the spec you want. I would advise you do not measure in inches, but use centimeters OR millimeters as that will make the measurement more accurate.
Apr 12, 2017 | The Computers & Internet
How do you remove vertical blinds
Vertical Blind Removal - YouTube
? 1:42
https://www.youtube.com/watch?v=DzjFN-6Ggsg
Aug 21, 2012 - Uploaded by Victory Curtains and Blinds
Vertical Blind Removal. Victory Curtains and Blinds ... How To Replace Vertical Blinds Changing Headrails ...
How to Remove and Install Vertical Blind Vanes - YouTube
? 0:44
https://www.youtube.com/watch?v=2FsauNXkRdw
Jun 10, 2013 - Uploaded by fixmyblinds
This short video will walk you through an easy way to bothremove and install the vanes on your Vertical ...
How To Replace Vertical Blinds Changing Headrails Taking ...
? 11:08
https://www.youtube.com/watch?v=XPgtms7rnQ0
Dec 15, 2015 | BrylaneHome Embossed Vertical Blinds...
Missing top bracket on order from home depot and they said it will take 2 weeks to get a missing top bracket form Mexico(Bali order) how do we get a top bracket to match the 3 shipped.
You might be able to find some online. I would also try some local stores for a replacement part. You might not get exact, but you could probably get close if you bring one of the top brackets with you.
Elisa Jed ' http://www.gotchacoveredwf.com/blinds/index.php
Feb 22, 2014 | Bali Blinds Blinds Bali Vertical Blinds 3...
Window blinds
I don't know about fixing them after they've become entangled, but I do know a thing or two about preventing them from ever getting tangled in the first place. One idea I've heard is to put the string inside a clear plastic straw, which would then help prevent the adjacent string from get tangled up with it. If you do have a serious tangle issue, sometimes it is easier to just replace it rather than try an untangle it. Or you take the whole unit off the wall and untangle it that way.
Feb 19, 2014 | Select Blinds 2 1/2" Deep Wood Blinds...
Good afrernoon, I posted my problem with blindes several weeks ago and nobody helped me... I really need help!!! I have classic white vertical wooden blinds in the window. Unfortunately something happend...
there are plastic gear inside of the top rail. you need to take the blind down and look inside. it may have some of the gear damaged. in which case the gear need to be replaced. unfortunately, there is no place sells the gear. only the rail.
that means you have to buy a new rail and go through the trouble of re-thread all of the control lines. if you are not handy, I suggest you take the blind to a repair shop.
Nov 28, 2008 | Hardware & Accessories
Hardware & Accessories Logo
1,588 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
