Question about Whirlpool Duet GHW9150P Front Load Washer
Soap leaking out of the bottom of washer
We have a duet and we  just moved the machine to a new location, the soap is leaking from the bottom of the machine onto the floor.  Could something have been dislodged from the move?  Thanks.
  • 63 Answers
Highly likely if you didn't use your shipping bolts when moving your tub cracked bottom of soap dispenser inside of washer buy warrnnty sear about 250.00."less soap plz"
Posted on Nov 15, 2008
My duet front load washer is licking water in front left side have any idea and how do u take off the bottom front cover
there are three screws under the front of the panel. make sure its not leaking from the door and running that way. if the bellow or door seal is damaged or bent or torn it will leak. please dont forget to rate me thanks
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Leaking from soap dispenser to front bottom door
hi this happened to me a few months ago u need to get a leak proof sealant and remove thee top of your washing machine the on the left hand side yoou will notice your soap compartment you need to seal this all the way round leave it to dry for two hours minimum then try running your machine again hope this helps.
Mar 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool front loader washer leaks water in front of the washer from the bottom of the machine. It does not happen with every load. Any idea on the problem?
Check the rubber boot just inside the door. You have to push the drum back slightly and rub your fingers around the entire boot. I had a similar problem and a key had fallen out of a pocket and cut into that boot. The leak would run out of the damaged boot then come out the bottom onto the floor. I purchased a new boot and it took me about 30 min to install it. The problem was solved. If the rubber boot is fine then the over soap thing is probably your problem.
Oct 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is leaking water when it starts from the soap dispenser
the fill tube is located at the top tub cover and more than likey the tube is defective or the discharge anti spash guard is cracked. nbcrca:)
Apr 11, 2009 | Washing Machines
Soap not being used
We learned from our new Duet that when washing with Tide soap powder, there is an adjustment inside the pull out drawer where the soap powder goes. You will see a grey plastic slider that goes to the right for liquid soap & to the left for powder soap.
Moving this slider to the left corrected this problem - not using all of the soap powder needed - for us.
Good luck !
Marilyn in FL
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Washer leaks from the door
Make sure the transit brackets and screws have been removed.
Other than that,I would say it needs a new door, as it is possibly twisted, and not closing tightly enough against the door seal.
Plz rate my suggestions.
Jan 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Soap not emptied
The soap tray has a plastic separator which has one position for liquid soap (the separator goes to the bottom of the tray).
It has a second position in which the separator leave a gap at the bottom so the powder can be flushed through.
I had put powder in the liquid setting and thus the soap did not get flushed into the washer.
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Front Loading HE washer is leaking! Hellllp!
hi there i would check the softner part of your soap drawer first for blockages, you can let me know
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer
maybe too much soap powder
cut down soap and use low suds powder
Jan 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
253 people viewed this question
Dan Webster
Dan Webster
Sal De
