New monitor hi, i have just bought a 19" monitor to replace a 15" one. my problem is there is a green line showing down the new monitor at exactly 15" across. is there anything i can do to erase this line? thanks
If you just bought this monitor take it back and get a different one. If you still have the same problem after that, then you have a video card issue.
Posted on Apr 06, 2009
There is a black horizontal line on my viewsonic LCD. It just showed up 2 days ago. But right now it looks green on this white back ground. What is this line? Why is it here? Can it be...
It is most likely that fixing this issue would be more expensive (and time consuming) than purchasing a new monitor outright. You can get a 23-25 inch LED monitor for $100-150.
Mar 03, 2018 | ViewSonic VP920b 19" LCD Monitor
New acer 19 " moniter plug in will not turn on ?
Try other outlet, check the power cord if it contacted the monitor. If nothing happened, maybe it's factory defect, since it still under warranty, you can still change it.
Thanks
Nov 09, 2008 | Acer AL1717 17" LCD Monitor
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Vertical green line somthing like an artifact
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 28, 2008 | ViewSonic VA1703wb Monitor
Heavy white lines accross the screen
Replace it, it is going bad. I could tell you what would cause this such as bad driver IC etc. but bottom line is its five years old, you got your moneys worth out of it so bite the bullet and get a new one.
Feb 11, 2008 | Envision EN 9110 19" Flat Panel LCD...
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
LG L1930B 19" LCD Monitor Problem... HELP
When an LCD Monitor starts to respond like this it is due to one of three reasons a power supply is not generating enough power to properly power the LCD or the LCD's backlight is beginning to burnout, and last the inverter is bad. These things all can be replaced, but it is not worth the cost! Easier and cheaper to buy a new one!
Nov 25, 2007 | LG L1930B 19" LCD Monitor
LCD... Problem
so I have the same problem. when you get the answer please send me an email with the info. I´ll do the same
uguetoe@gmail.com
Nov 25, 2007 | Gateway FPD1975 19" LCD Monitor
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
