My 16gb samsung thumb drive will not format in winxp. i have tried all of the online fixes but none seem to work. the drive is currently in the raw mode.
  • kylemc1985
    kylemc1985 May 11, 2010
    Hi there.
    What is the error message you're getting when formatting the device?
    Problem Solver:
  • 12 Answers
Hi again:
Unfortunately, jumpdrives aren't really suppose to be repartitioned. However, you my have to do some tweaking around to fix it. Here's how:
- Right click on the drive in My Computer, and click Properties.
- Click on the Hardware tab, select the device, and click Properties.
- Go to the Policies tab, click "Optimize for performance", then click OK and then OK once again.
The above steps will allow Windows to rewrite the sectors on the jumpdrive (also allowing the NTFS file system to work on the device). Now to repartition it.
- Go to Start > Run, then type "diskmgmt.msc" (without quotes) and click OK. This will start the Disk Management services.
- Right click on the partition on your jumpdrive, and click "Delete Partition...", confirm the deletion.
- Right click on the Unallocated space, then click "Create Partition...", create a partition the full size of the available space. When it comes to the Format option, select "FAT32" and "Quick Format" options. Continue through the wizard and confirm all modifications.
This should allow for Windows to recreate the partition table and file system. Hope this works!
-Kyle-
Posted on Nov 13, 2008
Windows was unable to complete the format. I think the drive is toast ie: I used an older version of fdisk and format and it came back and said track 0 bad disk unusable.
Posted on Nov 12, 2008
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
ok...
Regards
Uttam
Jan 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I bought 2 16gb sdhc cards and cant format them in
you can try to format them on your computer if you have sd drive. Otherwise I would suggest returning those ones and get something different. Sandisk is a good brand.
Jun 04, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
MY KINGSTON 2GB pen drive shows zero spacing......
do you still have warranty for the Pen drive, suggest you take it to the shop you bought it. you seem to have got a defective ped drive. also if you have the serial numbers, check online with Kingston to see if you have got a genuine kingston product.
Feb 02, 2009 | Electronics - Others
The file system of my hard drive become RAW.
http://www.z-a-recovery.com/unformat-tutorial.htm
This tutorial describes the procedure to recover one volume when
  • the volume was accidentally formatted
  • Windows reports the volume is "raw filesystem", or "not formatted"
  • An external drive failed, either flash (so called "thumb drive") or an hard disk connected using USB or FireWire enclosure.
  • MFT is corrupt on the NTFS volume, rendering filesystem partially or completely unreadable
The recovery is done in seven steps, requiring about eleven (11) mouse clicks. Note: The older than current versions of ZAR might have been used to create the screenshots in this tutorial. We did not update the screenshots if there is no significant difference between older and current versions. If you see some option in the program which is not described in the tutorial, just leave it at its default setting.
plashkablue_left.gif Step 1 - Get, install, and start ZAR
plashkablue_right.gif box-top-l.gif box-top-r.gif Download and install ZAR just like you do with any regular program.
When you run it, ZAR displays the window like the one below:
  1. Click "Next >>"
plashkablue_left.gif Step 2 - Select processing mode
  1. Select "Recover data from a simple volume or from a functional RAID volume"
  2. Click "Next >>"
plashkablue_left.gif Step 3 - Select physical device to recover
  1. Select the appropriate hard drive
  2. Click "Next >>" for a list of volumes (logical disks) on this hard drive
Nov 19, 2008 | Western Digital My Book Essential Edition...
Can't format my sandisk micro cruzer 16gb flash drive
Try this --
Download the HP disc format tool using this link--
http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
After downloading the file you need to install this.
After installation,launch the software, and select the Flash Drive Letter and try formatting.
If this does'nt work,plz let me know and I'll give you one more alternative.
Nov 13, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Oct 24, 2008 | Transcend (589307) Media
My usb flashdisk become raw data
1). Do not format this hard drive before you've recovered all your stored data back. In your case, the formatting process may erase everything on your drive and make your data gone permanently.
2). Never save anything new on this drive in case that any new file would rewrite your original data.
3). Plunge this drive to your computer and download a RAW drive data recovery freeware to get back all your lost data back:
http://www.freeware-fix.blogspot.com/2013/02/raw-hard-drive-recovery.html
This hard drive has helped many people around me restore their inaccessible data back from a RAW drive or memory card. It can also work perfectly on your drive.
Read more detailed information of this freeware here:
http://blog4mark.blogspot.com/2012/10/help-external-drive-became-raw.html
4). Save and back up all your restored data on another drive in case of data recovery failure.
5). Format this drive to see whether it is fixable.
Dec 16, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
David Payne
David Payne
