Question about Logitech X-530 Computer Speakers
Logitech Computer Speaker X-530
While moving my computer from one place to another, I connected the "parallel" data cable (hope I used the right terminology) to the monitor outlet on computer. Soon after that I corrected this mistake. Since then I could not get the power on speaker (the green light not glowing) and the speaker doesn't work. Is there any fix for this, like changing the fuse or something? I cost of the speaker was about $50. Any input to fix this cheap would be greatly appreciated.
  • Sriram Venkatraman Nov 13, 2006
    Just a clarification: I connected the data cable from the speaker to the monitor outlet in the computer.
We did the same thing. I opened up the system and noticed the fuse had blown. I had to unsolder the fuse to remove it from the circuit board. I believe it needs to be replaced with a slow blow 250 volt 5 amp fuse.
Posted on Feb 16, 2007
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
How do you connect the logitech x-530 surround system to an xbox360?
In the right part of the image,you have an RCA-RCA cable,the other side of the cable,connect it into the back of the xbox at the right and left RCA sockets
Oct 01, 2010 | Logitech X-530 Computer Speakers
How do i connect Logitech X-530 to my TV?
Connect the audio cables (red to red, white to white) from the audio out on the back of your TV to the audio in on your speaker system.
Feb 22, 2010 | Logitech X-530 Computer Speakers
X-530 logitech surround speakers how do I install please
coming from the speaker with volume control, there is a cable with 3 jacks, connect them while your computer is running, yellow to pink, green to green, black to blue. a window should open asking what you connected. green is front, yellow is center/sub, black is rear
Dec 27, 2009 | Logitech X-530 Computer Speakers
Only two speakers are working I have vista ultimate install in my computer , I have logitech X-530 speakers
Helllo there!
You have to make sure you have in control panel your audio sound card, well installed and is working right. Then go to control panel and see your speaker configuration, is suppose to be at 5.1 speakers also you can use 6.1 Speaker configuration. Be sure you connect right your speakers at back of the audio jacks!
that's it!
good luck!
Open Sky
Dec 08, 2009 | Logitech X-530 Computer Speakers
I moved my computer andwhen i plugged everything up... the speakers wouldnt work
You should check the connection between the speaker and computer, be sure that the green jack is plug in to the same color of the back of the computer audio out. If the problem persist. Check the power supply of the speaker to determine that there is power to it and if still doesn't work, try using the speaker to your ipod or mp3 player to know if the problem is in the speaker or in the computer. Hope this could help you..Thanks..
Oct 24, 2009 | Logitech X-530 Computer Speakers
X-530 one speaker not working
this is a problem that i have faced as well it is likely that the cable going in to the jack could be loose and you might need to move it a bit, but in your case i think most likely would be that the input jack on the sub for the speaker is broken in that case you should call up logitech and ask technical support to see what they can do for you should be covered by warranty!
Feb 09, 2009 | Logitech X-530 5.1 Channel Speaker System...
One speaker is musch louder X-530
On the TV sound options see if there is a balance option. Adjust according to taste if there is that option. Hope this helps.
Dec 24, 2008 | Logitech X-530 Computer Speakers
Logitech X-530 Computer Speakers Logo
356 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
